Goodman Heat Pump Problems
Old 07-18-2010, 10:17 AM   #1
Bamaman's Avatar
Trade: hvac
I have a goodman heat pump that is acting very strange. It has a new compressor yet the coil acts as if it is starving for refrigerant. I think it may the reversing valve not acting properly but not exactly sure just how to test it. Any help with this would be appreciated.
Bamaman is offline
Old 07-18-2010, 07:04 PM   #2
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,078
Re: Goodman Heat Pump Problems
What are your readings. Head and vapor line pressure, and line temps.
indoor and outdoor temps and humidity.
Indoor air flow in CFM, not it blows hard to your hand.
beenthere is offline
Old 07-19-2010, 08:21 PM   #3
Been there done that
Bigpapa05's Avatar
Trade: Certified General, Plumbing, & HVAC Contractor
Too Funny
Bigpapa05 is offline
Old 07-20-2010, 08:00 AM   #4
Bamaman's Avatar
Trade: hvac
The unit has a new compressor. The low side reads 90 psi and the high reads 220psi. The ambient temp is 95 degrees. the supply is reading 67 to 71 from the indoor unit. The house feels cool although it will only pull down to about 75 degrees at night. I have a good charge on the unit and the orifices are clean at the coil and the condenser. Could it be the thermostat which is a white rodgers electronic?
Bamaman is offline
Old 07-20-2010, 09:01 AM   #5
beenthere's Avatar
Trade: HVAC
Is it an R22 unit, or an R410A unit.
If R22, the evap is flooded. Could the piston be in backwards. Could be that your having a problem with the reversing valve sticking.
If 410A, looks like it may be under charged.
Doubt its a problem with the thermostat.
What was wrong with the old compressor.
Old 07-20-2010, 08:32 PM   #6
Bamaman's Avatar
Trade: hvac
the old compressor was grounded. I replaced the compressor, pulled a vacuum, charged with R-22 and started it up. The temp went down to low 60s while charging then shot back up to high and low seventies and thats where it remains. checked pistons and they are in right position. I just think the reversing valve is sticking, not sure. I'm not to sure exactly how to test it without removing it from the unit. I am attempting to help my son since he has a new born in the home. Thanks in advance for your assistance.
Bamaman is offline
Old 07-20-2010, 09:16 PM   #7
beenthere's Avatar
Trade: HVAC
Throw it in heat for a minute. And see what it does.
You can do a temp test across the RV.
Air Tap Heat Pump water heater? Dbower Plumbing 7 07-05-2010 08:05 PM
Heat pump SEER readydave8 HVAC 4 06-13-2010 06:14 AM
heat pump covered with ice AustinDB HVAC 7 02-21-2010 05:15 PM
Need help with my shop heat pump DeanV HVAC 2 02-12-2008 09:20 PM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 04:38 PM
