Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 10-20-2005, 12:55 PM   #1
Trade: Maintenance Tech
Goodman GPD075
Getting a pressure switch stuck closed code. Replaced switch, checked tube, flue etc. Tried jumping pressure switch wires and received a faulty flame sensor code (ignition would not start as well). Any suggestions?
DOZER is offline   Reply With Quote
Old 10-20-2005, 11:05 PM   #2
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
I would check the inducer motor and make sure there is nothing inside the housing blocking the pressure switch port and also take a magnahelic guage and see what the W.C. is that it is pulling just to make sure it is running full RPM's. Remove and clean the flame sensor as well (if you haven't already). If all the above check ok, time to look at a control board.
HVAC Doc is offline   Reply With Quote
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-28-2008 11:05 PM
Another Goodman GMP-075-3 problem rhinoguy HVAC 10 12-02-2007 04:16 PM
Goodman not cooling MikeT HVAC 6 07-05-2006 02:25 AM
2 blinks on goodman furnance? Herman HVAC 2 04-09-2006 10:16 PM
Goodman furnaces? oldgoat HVAC 3 02-22-2006 10:07 PM
