Goodman GMT045-3 Blower Problem
Old 02-14-2007, 05:13 AM   #1
GaryStevens's Avatar
Trade: General Contracting
I have the above furnace and I am having an issue with the blower. When the heat kicks on the exhaust fan will turn on, the ignitor glows, the gas lights and stays on but the blower never starts. The gas and flame continue to burn. I have also noticed that the fan swith on the thermostat will not turn the fan on. But the fan works if I switch it over to A/C so I know the motor is good.
Will this require the board to be replaced or is this another part causing the blower not to start?
GaryStevens is offline
Old 02-14-2007, 08:34 AM   #2
HVAC SERV OWNER's Avatar
Trade: HVAC
Re: Goodman GMT045-3 Blower Problem
COULD be either the fan relay board or the seperate fan speed in the motor is bad. A/C runs on either high or med. speed and heat works on med or lo speed. You may need to call a service tech. to repair it. Good luck.
HVAC SERV OWNER is offline
Old 02-23-2007, 12:17 AM   #3
Astar Heating & A/C CEO
FemaleAstarCO's Avatar
Trade: HVAC Contractor
Send a message via Yahoo to FemaleAstarCO
I had that same issue last week it was the fan center.
FemaleAstarCO is offline
Another Goodman GMP-075-3 problem rhinoguy HVAC 12 12-05-2010 06:52 AM
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-29-2008 12:05 AM
Well problem paintr56 Plumbing 10 02-09-2007 09:20 AM
goodman blower motor mholl HVAC 3 03-30-2005 09:17 PM
Goodman ignition problem dansbonne HVAC 4 03-21-2005 06:58 AM
