Goodman Gmp Flame Problems
Old 01-16-2005, 09:46 AM   #1
Tim Geiger's Avatar
Hello, This question pertains to Gmp Goodman furnaces approx. 8 - 10 yrs old. I have normal ignition sequence and burner will light for several minutes. Main blower kicks on and no real change in burner flames. For unknown reason the flame in the end burner sometimes 2 burners will start to pop on and off until the gas valve closes on flame sensor signal loss. I have monitored the gas pressure at the outlet of the gas valve during this event and it does not change.
I cleaned the burners, removed the burner nozzles and examined no knicks or burrs. When I reassebled the event reoccured one time. Since then I have not had a complaint.
I now have a service call for tommorow with a similar complaint on a GMP but not the same furnace.
I am still in doubt about the first one because of the single reoccurance.
Anyone have any thoughts?
Tim Geiger is offline
Old 02-05-2005, 09:15 AM   #2
bigdogx01's Avatar
Re: Goodman Gmp Flame Problems
SOunds like a blow back. Try cleaning the orifices and check for trash in the monifold.
bigdogx01 is offline
Another Goodman GMP-075-3 problem rhinoguy HVAC 12 12-05-2010 06:52 AM
Construction Records Problems PalAl2000 Commercial Construction 5 05-15-2007 07:56 PM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Solving Problems dayspring Off Topic (Non Trade) 13 06-15-2006 08:45 PM
Flame Sensor darren HVAC 2 01-16-2006 01:28 PM
