Don't mess with the ignitor. You said it came on, so it's probably ok. They break easily. It sounds as if the gas valve is the culprit. However, that is based on very little info. The parts are under warranty still, but manufacturers do not like to replace parts that work ok. I know fixing stuff is fun, and gratifying, but a Goodman dealer, or any other hvac outfit probably could make kids play out of this problem. Sorry to hear you are having problems, but Goodman isn't a bad company, and they are likely to stand behind their product. But, you need to let them know the problems you have had.
