Goodman Furnace Won't Shut Off
Old 02-10-2005, 01:16 PM   #1
anonymous's Avatar
Smile
I have a Goodman GMP 075. It's approx. 10 years old. 6 weeks ago it wouldn't come on and cycle properly so it was cleaned and we had the ignitor and blower replaced. It worked fine until yesterday. Now it won't shut off unless I trip the switch. The thermostat is new. Any comments?
anonymous is offline
Old 02-12-2005, 09:48 PM   #2
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
Re: Goodman Furnace Won't Shut Off
Check the wiring in the furnace at the low voltage terminal connections.
Check the wiring to the thermostat, make sure the color codes correspond to the color codes at the furnace (R red = 24v supply into t-stat, and W white is 24v out to the heating circuit.)To diagnose simple disconnect one of the 2 heating wire (R or W) and unit should cycle off. If not, the problem would be found in the furnace wiring. If it is a round T87F type t-stat, make sure the red shipping plug is removed. Good luck!
:Thumbs:
NickTech is offline
Quality of Payne furnace ??? Home Pro HVAC 45 03-30-2010 10:10 PM
need furnace expert - Goodman furnace DMC HVAC 22 02-19-2009 01:24 PM
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-29-2008 12:05 AM
Goodman Furnace won't ignite RocMods HVAC 6 03-16-2005 10:34 AM
need info on a goodman gus 075-3 older 90% furnace haank HVAC 0 09-29-2003 11:02 PM
