Goodman Furnace Mod # GMPN100-4
Old 01-26-2004, 04:17 PM   #1
big waynester's Avatar
It will run for about 5 min, then shut off, I get 3 blinks on the status light. I have no book with this unit, so I don't know what this means, but it was installed in late 1999. Is there any thing I can do? I hate to call the guy that installed this.
big waynester is offline
Old 01-26-2004, 07:27 PM   #2
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Lightbulb
Re: Goodman Furnace Mod # GMPN100-4
You should be able to find a diagnostig cade inside the unit or on the control module itself. If I was to take a guess i would say the unit is over heating and tripping your limit switch. Make sure the filters and coil are clean that switch will open in the low to mid 200's.
Old 01-27-2004, 05:42 AM   #3
Bjd's Avatar
Most flash codes are also labled on the inside cover of the unit, locate the flash codes and get back to us.
bjd
Bjd is offline
Old 01-27-2004, 01:26 PM   #4
Doh! I was looking on the inside of the furnace for the codes, they were on the cover. The error is "Pressure Switch Failure to close" is says to check, Ventor, Pressure switch, and Vent blockage.
While the furnace was running, since it is cold, I can see it is venting.
Can someone tell me how to check the other things?
Another thing this is a down flow furnace, it is in the mezzanine in my barn, I don't have the furnace on all the time, the condensation line runs along the ceiling of my barn to the other side where the drain is. If water froze up in the line, would it cause this error?
Old 01-27-2004, 02:22 PM   #5
the pressure switch had water in it.Is this normal? I tested the pressure switch by blowing air into it and ataching a meter, the switch seems OK
Old 01-27-2004, 04:10 PM   #6
I think I kind of have it fixed, to much condensation in the vent blower, backed up to the pressure switch hose and got into switch, now I got to figure why this happened
Old 01-27-2004, 09:48 PM   #7
Allen's Avatar
Check to make sure that the vent for the exhaust is at a downflow angle toward the furnace.if it's sagging water will build up
Allen is offline
Old 01-28-2004, 06:06 AM   #8
Bjd's Avatar
You bet your a$$ that would cause that type of failure, water in the switch line frozen will not allow the switch to operate. I work on a bunch of these units that are in a skate rink, its very common for this to happen to them.
BJD
Bjd is offline
Quality of Payne furnace ??? Home Pro HVAC 45 03-30-2010 10:10 PM
need furnace expert - Goodman furnace DMC HVAC 22 02-19-2009 01:24 PM
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-29-2008 12:05 AM
Goodman Furnace won't ignite RocMods HVAC 6 03-16-2005 10:34 AM
need info on a goodman gus 075-3 older 90% furnace haank HVAC 0 09-29-2003 11:02 PM
