Unregistered
Guest
Posts: n/a
Goodman Condensing Unit Control Wires
i have just installed a new heating system in my home. the tstat wiring from the furnace to the thermostat was clear but i can't figure out how the control wire works from the condensing unit. the condensing unit has two purple wires.
The Doctor is In!
Trade: HVAC owner
Re: Goodman Condensing Unit Control Wires
Those are your low voltage connections. Simply hook your two wire (normally red and white wires) one to a red and one to a white.
Unregistered
Guest
Posts: n/a
Go ahead wire it yourself, burn up a transformer then you really wont have a clue. Just call a local contractor and have him hook it up for you. Plus that way your warrnty will not be voided.
Unregistered
Guest
Posts: n/a
hopefully you installed it correctly but seeing that you dont even know how the remedial wiring should be you should stop and run out the door now before you do any more damage then from a payphone far away call you nearest hvac person. Also, there is a reason why on the front of the installation manual it say that a professional hvac contractor should install it and not a home depot or lowes question asker!!!! THANKS FOR THE LAUGHS
What is up with all of these "Unregistered" individuals and their snobby comments. It is very unprofessional and a little tacky...
Richard Johnson VP-Operations ClimateMaster Mechanical, Inc. |
| Goodman 80% furnace brand new won't start | Hguy | HVAC | 21 | 03-29-2008 12:05 AM |
| Stretching wires 18 inches? | Mike Finley | Electrical | 34 | 11-30-2006 07:35 AM |
| Number of wires in switch box | remoguy | Electrical | 1 | 11-16-2006 10:02 PM |
| Used the mini skid today-Toro Dingo tracked unit | IHI | Tools & Equipment | 5 | 06-13-2006 09:22 PM |
| New Central Air Unit for Ranch House | Robie | HVAC | 9 | 03-25-2006 10:01 PM |
