Goodman Blower Motor
Old 03-29-2005, 08:48 PM   #1
mholl's Avatar
i have a goodman gmp 100 and the main blower comes on at will with the thermostat off . it may cycle on for awhile one day and then not again for a couple more days or it might cycle on and off all night.the only way to stop it is to kill the power. could this be a bad board ?
mholl is offline
Old 03-29-2005, 10:37 PM   #2
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
Re: Goodman Blower Motor
sure, a bad board may present these symptoms. there are other culprits that may be responsible for the problem. there may be bad wiring from the t stat to the fan relay control in the furnace causing this to happen. the hi limit my be tripping off due to hi temp in the furnace, as well as the hi limit going bad, which will trigger the blower motor to come on.
NickTech is offline
Old 03-30-2005, 07:40 PM   #3
mholl's Avatar
where is the hi limit located?
mholl is offline
Old 03-30-2005, 09:17 PM   #4
NICKTECH
NickTech's Avatar
Behind The Gas Valve, Mounted On The Rear Wall Of The Furnace. It Is A Black Square With 2 Terminals Coming Off It. There Is A Thermistor Limit Mounted To The End Of An 8 Inch Extention.
NickTech is offline
blower motor constantly running newcomer08 HVAC 3 06-07-2007 11:43 PM
Goodman GMT045-3 Blower problem GaryStevens HVAC 2 02-23-2007 12:17 AM
Electrically operable Velux skylight motor size Brendakeen Electrical 12 11-28-2006 01:38 AM
Motor Capacitor Leo G Electrical 4 09-12-2006 10:48 AM
Slow motor jbfan Electrical 4 06-29-2006 09:12 PM
