Goodman/Badfurnace:GMP125-4 Gas, On Ignition
Old 01-27-2007, 01:10 PM   #1
fitzy888's Avatar
Trade: engineer
Goodman Goodman (GMP125-4), gas, no ignition
I mention the following that it may help someone with one of the many problems they can expect with a Goodman Furnace. Mine came with the house, we bought from an old couple (nice house) they got screwed for $3,000 on this POS perpetual service requiring furnace.
One blink:
-Check the hot surface igniter, (don't touch the element).
-Un snap the connetor, check the voltage to the ignitor with a multi-meter, mine showed voltage for only a split second -the problem.
-Reset, turn it off and on, at the switch or breaker.
-The controller, this is an integrated curcuit which for my furnace is made by Goodman (to thier high standards).
-So, to replace the controller you must invest more in the Goodman name, to add insult to injury.
-I would be willing to pay triple for a controller from Honeywell or Johnson, just to know that my expediture doesn't benefit Goodman or a Goodman dealer.
What I learned in two short years is that Goodman (Janitrol) furnaces are crap!
fitzy888 is offline
Old 01-27-2007, 10:53 PM   #2
Thoroughbred Mopar Man
#CARRIERMAN's Avatar
Trade: Railroad Conductor/ Ex Hvac Service manager
Re: Goodman/Badfurnace:GMP125-4 Gas, On Ignition
Hi fitzy888
I thought this particular POS used a seperate ignition module. If this is so, use a honeywell S8910U1000 to replace it with. If its the Smart Valve system. Get you a five gallon bucket of vasoline and a bar stool. This aint gonna be a comfortable prostate exam.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline
Old 01-31-2007, 03:42 PM   #3
Jmorriz's Avatar
Trade: Technician
One blink:
I have the same problem with my furnace now. Same deal, pruchased with the house. The furnace kicks off and sometimes cycles on its own. Most times the thermostat has to be turned off for a few seconds then turned back on. The furnace works perfect after that to bring room temperature to the set temperature. Everything appears to work down to the board. What a shame to have to spend hundreds of dollars on this part along with labor. Goodman is a cheap product that new construction is using to cut cost.
Jmorriz is offline
Old 02-02-2007, 10:04 PM   #4
NCSteve's Avatar
Trade: hvac
I subcontract for a big goodman dealer, I work on goodman gas furnaces all day long, I can tell you it is a cheap furnace, the company I sub contract for went from a trane dealer to a goodman amer standard dealer what a jump.
NCSteve is offline
Old 02-05-2007, 01:28 PM   #5
Astar Heating & A/C CEO
FemaleAstarCO's Avatar
Trade: HVAC Contractor
Send a message via Yahoo to FemaleAstarCO
Fitzy we call them Goodjunk. Also are Amana now.
FemaleAstarCO is offline
Old 02-07-2007, 05:14 PM   #6
I agree Trane is by far a better unit.I am a former American Standard dealer. Due to the shipping I switched to Trane. American Standard is Trane. Trane owns American Standard. My Rep for Trane actually grew up in the factory and said they actually come off the same line. All my Trane dealer info says American Standard on it on the signature lines. Goodman has gotten better but is still junk. The cabinets are made terrible after a few years it makes quite a lot of noise. Amana has changed some of it but I am not overly thrilled with them either. The warranty is great but lets see how long that holds up.
Cindy
Old 08-26-2008, 05:31 PM   #7
cgazaway's Avatar
Trade: HVAC
these boards are manufactured by White Rodgers (an Emerson Company, see also Copeland, Alco, etc) not by Goodman. this board actually has a low warranty rate in comparison with other makes.
cgazaway is offline
Old 08-27-2008, 01:35 AM   #8
flashheatingand's Avatar
Trade: H.v.a.c.
One blink:
How old is the furnace? If it is the one I think you are mentioning, it would be covered under the warranty (part only). The Goodman company is aware that they had a bad stock of control boards for furnaces that were made around 2005 and are happy to make good on it. If you replace the board with a universal Honeywell board or anybody else, then you will have no re-course. If you are that dissatified with that product, then get a different brand. However, every brand has their flaws, Goodman isn't the only manufactorer that has had sub-par control boards.
It's too bad that you aren't happy with your furnace, but, when comparing apples to apples, they all are about the same. Just my humble opinion
flashheatingand is offline
Old 08-27-2008, 01:50 AM   #9
Trade: H.v.a.c.
I worked for a Trane dealer, and ventured on my own, and sell mainly Goodman. I will grant you that the tech help with Trane, and their training program is heads and shoulders above Goodman. In my opinion, that is the major flaw with Goodman. However, when comparing the furnaces themselves, the difference is quite small. The door knobs (on Trane XR models) are a nice feature, and there may be a couple of other things that I am missing, but the motors are about the same, the boards, ... etc. they are all about the same.
Perhaps the reason People perceive Goodman as crap versus Trane is because The Goodman suppliers aren't as selective as to whom they sell their product. As a result, they are victims to poor installations. However, Tranes will not perform so well with a poor installation either.
Old 08-27-2008, 07:34 PM   #10
HVAC Tech, NATE certified
Verbal's Avatar
Trade: Hvac technician. Boehmer Heating
Was it goodman that used to use the Texas Inst. boards that had the lock out ghosts in them?
Best line from a customer "you here for the tune-up? the tank of 22 is in the shed, let me know if you need more."
Verbal is offline
Comfortmaker Furnace ignition problem J1CS HVAC 2 10-17-2005 02:39 PM
carrier ignition problem typhoon55 HVAC 8 06-06-2005 12:31 PM
Carrier Ignition Lockout user33 HVAC 18 05-21-2005 07:54 PM
bobcat ignition colandscaping Construction 4 04-02-2005 03:52 PM
Goodman ignition problem dansbonne HVAC 4 03-21-2005 06:58 AM
