GMPN100-4 Coil Red/no Flame
Everything seems to be in order, accept I'm getting no flame. The unit starts and a few relay cliks later the glow coil gets red, then no flame. The status LED shows 1 blink. I'm leaning toward this being a gas flow problem, perhaps the flow switch. Might I have forgotten to pay the gas bill this month? Please help, it's cold!
#2 | |
Re: GMPN100-4 Coil Red/no FlameQuote:
is the gas valve on? what's a flow switch? |
NICKTECH
Check the gas cock to see if it on, then check the top of the gas valve, there should be an on off switch, make sure it is on. after the glow coil turns orange (1900 degrees) and gets a bright as it can, do you here another click? this would be the gas valve energizing and opening to feed fuel the the burner. it can be a loose wire issue. is there any smell of gas? if there is then the ignitor may be misalligned and it shuts down on no flame signal.
| coil replacement | kyhtb | HVAC | 11 | 02-19-2009 08:26 PM |
| Hydro Air Coil | ofourcobra | Plumbing | 4 | 10-16-2006 10:17 PM |
| trim coil window stops ,casing, quad caulk for sale ..closing shop | window man | Contractor Swap | 7 | 07-05-2006 09:46 PM |
| Steel/vinyl coil stock. What to look for.. | GiantScale | Roofing | 2 | 04-13-2006 07:38 PM |
| Flame Sensor | darren | HVAC | 2 | 01-16-2006 01:28 PM |
