Geothermal To Heat House Under Construction?
Old 11-24-2008, 08:19 PM   #1
GregWCIL's Avatar
Trade: General Contractor, tiling specialty
New residential home construction. ICF walls, geothermal furnace doing both forced-air and hot water for radiant heat in basement concrete floor.
Any reason I can't have the heating subcontractor go ahead and install the geothermal furnace but only hook up the radiant heat part in the basement floor? I think it would keep the house temperature at a reasonable level during inside construction phases this winter.
I understand why you wouldn't hook up the forced-air part due to dust etc., but are there any moving parts in the hot water part of a geothermal furnace that might be harmed by drywall dust, insulation fibers, etc.?
My heating sub has never done this before but we don't know why it won't work.
Thanks in advance,
Greg
GregWCIL is offline
Old 11-24-2008, 11:14 PM   #2
flashheatingand's Avatar
Trade: H.v.a.c.
Re: Geothermal To Heat House Under Construction?
The compressor is located outdoors? or is the compressor going to be installed in the air-handler?
flashheatingand is offline
Old 11-24-2008, 11:49 PM   #3
Kgmz's Avatar
Go ahead and do it, it will be much nicer working.
I do this even with a normal heat pump. The drywall guys like having the nice dry heat to help dry things out. But I do put filter material on all vents, heat vents and return air. The filters over the floor vents are just mainly to keep crap from falling in off of the floor, and any drywall mud and texture.
Kgmz is offline
Old 11-25-2008, 01:19 AM   #4
Young Gun
HallisseyDesign's Avatar
Trade: Smartass
also if you can put the cheapo filters in it for the furnace. That is what we do and replace them every week or so. Beats the hell outta freezing first thing in the mornin and that last tool your wrapping up at the end of the day! just set the temp to the lowest setting. Mine is 55 more then bearable to work in.
HallisseyDesign is offline
Old 11-25-2008, 05:35 PM   #5
GregWCIL's Avatar
Thanks guys--
Hall and Kg - I don't think we will even need the forced air part if we get the basement concrete floor up to decent temp.
Flash - there is no compressor outside, it's a Waterfurnace ground-coupled heat pump Synergy 3D model.
We could put in a temporary furnace, but I figure we might as well use this since it is the most efficient way to do it.
GregWCIL is offline
Old 11-25-2008, 07:33 PM   #6
palacegeo's Avatar
Trade: Geothermal Systems
Your idea to just use the water side is the best approach.
Just be aware the it will void the warranty if you use it for construction heat.
Dewayne Dean
www.palacegeothermal.com
We heat and cool with dirt.
Why settle for 90% when you can have 400%
palacegeo is offline
Old 11-25-2008, 09:09 PM   #7
Kgmz's Avatar
You gotta be kidding, why would that void the warranty?
Kgmz is offline
Old 11-25-2008, 09:41 PM   #8
palacegeo's Avatar
If you don't understand the damage caused by running a new heating unit for construction heat, then you should turn in your contractor license.
Dewayne Dean
Old 11-25-2008, 10:27 PM   #9
GregWCIL's Avatar
Dewayne -
I'm not the heating contractor, but I don't see why it would be a problem in this case. The house, being ICF, is already airtight and insulated on the walls. Windows, doors (maybe only temporary) will be in place and the cellulose blown in above the ceiling.
Why no warranty?
GregWCIL is offline
Old 11-26-2008, 01:30 AM   #10
palacegeo's Avatar
It is the manufacturer who makes up the terms of the warranty.
I have done the very thing you are contemplating on a radiant system after telling the owner of the warranty issue.
I just wanted to make you aware of the warranty issue.
FWIW, I would never use a forced air geo unit for construction heat.
Dewayne Dean
every year house Traditions2 Painting & Finish Work Picture Post 3 12-06-2010 11:48 PM
Flat plate heat exchanger genecarp Plumbing 2 11-24-2008 10:09 PM
need help with construction window cleaning Final Touch General Discussion 4 10-27-2008 01:59 PM
house alarm in trailer cooks Low Voltage 7 10-24-2008 09:59 AM
Future construction/ bank loan/ and quit claim question?? kdub1777 General Discussion 0 08-24-2008 09:54 AM
