Geothermal And Floor Heat?
Old 12-18-2010, 06:25 PM   #1
Williams Ex Co's Avatar
Trade: Excavation, land clearing, sewer/water
Rewards Points: 250
I will be adding on to my shop next spring, can geothermal be used for floor heating? Addition will be 40 x 64. Any pointers ya got are appreciated. Thanks!
Williams Ex Co is offline
Old 12-18-2010, 08:38 PM   #2
ciws14's Avatar
Trade: Geothermal, HVAC
Re: Geothermal And Floor Heat?
You can use geothermal for the floor heat. They make combination units that will heat the air and the slab accordingly. I would not recommend it for a shop environment.
You will still need a source of back up heat for extreme weather conditions. If overhead doors are open during the winter the recovery time can be substantial. Even though Water to Water heat pumps are made up to 15 tons, you will not be able to set your shop back very much during unoccupied times due to the recovery time. I would think about a hi-efficiency modulating boiler for this instance maybe. That is what I have in my shop. I have a small Geothermal unit that serves the offices, but the shop floor itself is run from a boiler.
Good luck.
ciws14 is offline
Old 12-18-2010, 10:20 PM   #3
Rewards Points: 250
Thank you! This addition will have one large door, 20'w x 15'h so my guess is I will lose a huge amount of heat each time it cycles... Maybe geo isnt a good match for this project. Im just looking for options as I have done the excavation side of some 'slinky' systems and and looking into buying a HDD machine next year so could go that route too...
My father in law has a boiler system for his shop floor heating... Munchkin is the brand name I think. 40x96... Seems like he goes through a lot of LP though. Would love to be able to set up a system that uses geo to keep the temp a constant 50-55 and boiler back-up for the crazy stupid cold Iowa winters... Thanks for the tips!
Old 12-19-2010, 06:37 AM   #4
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,114
If you go with a geo. Then you can't use temp set back when your not there. Shouldn't use it with a boiler either. As it will take a long time to reheat the floor/slab.
How the radiant is installed also has a lot to do with how much LP your FIL uses. If he used 9" OC instead of 6" OC, then he needs to use a higher water temp, which reduces the boilers efficiency.
beenthere is offline
Old 12-19-2010, 09:32 AM   #5
Rewards Points: 250
Probably wont need to use a temp set back.... 50-55 degrees would be constant temperature. Warm enough to melt snow off over night and still a pretty comfortable working temp....
Old 12-19-2010, 06:26 PM   #6
ciws14's Avatar
Then you may be a good candidate for a Water to Water unit. You will still need a back-up heat source such as a boiler or unit heater for extreme weather conditions and if you decide to crank up the heat to do work on equipment and so forth. You will certainly save money over fossil fuels, but sizing is absolutely critical in this application. If there is too great a heating load on the building and the Water to Water unit is not sized correctly, then the unit will be "Spinning it's wheels" and never get shut off nor get the building up to the desired temperature.
Shoot me a PM if you would like more information. Good luck.
ciws14 is offline
Old 01-21-2011, 10:26 PM   #7
BigHouseBuilder's Avatar
Trade: house builder
Most of our homes have geothermal and infloor heat. You will need a water to water unit. Check out water furnace. They make a great unit.
BigHouseBuilder is offline
Old 01-27-2011, 11:00 AM   #8
JosieJO3197's Avatar
Trade: HVAC Contractor
Run heat loos / heat gain loads on your space. Find a reputable GeoExchange contractor and check his references. A water to water unit will act as a boiler and heat your floor. Your feild will be another important step. Whether you go vertically or horizontal, again make sure you use someone who knows what they are doing. The field is the heart beat of your system. Also look into the tax credits will can get for a commerical installation.
JosieJO3197 is offline
