Gas Regulator
Have two ventless fireplaces, one under the other ( top floor and basement). Both require an external regulator. Do these (it) have to be on the outside of the house? If so, I will need to branch off line going to central unit and install pipe parallel to existing pipe. If not, I can branch off from existing pipe past the unit.
P.S. This is not for a customer. |
Trade: Plumbing and heating
Re: Gas Regulator
Check your local code ,but I have used "limited vent" regulators indoors with out a vent pipe.
Re: Gas Regulator
I've decided this is over my head, have to pass. Too many guestions on my part. One reg handle both without cutting pressure down, etc.? Insurance coverage....? Its for my son. A not up to par paint job I can live with if he can. It can be fixed. Gas is another thing! I told him he should get someone lisenced and more experienced than me. Just too damned risky. He says his dad-in-law can do it. You know I'm still concerned! I don't remember ever installing one with this requirement.
Re: Gas Regulator
Son just called asking if i had a flaring tool, etc.. Said the guy at the supply house asked if he was he was on city gas. He is. Guy told him he did not need the extra regulator, the heaters have their own. I knew they had their own regulators. But, the instructions did not say "unless on municiple gas sysytem". They did say the regulators on the heaters may be damaged without the external reg. So he/they will be using my tools. Didn't even ask about pipe cutters, dies, etc..
I did wonder about the municiple gas thing, but did not know. STILL do not know! Oh well, just babbling a little. |
Trade: Squirrel Handler
Re: Gas Regulator
I've never heard of having to have an external regulator for a fireplace, aside from the one that every fireplace I have seen come with and the one at the service entrance. We have a building that had 5 furnaces explode (the whole block was effected) because the Gas Company opened a valve to quick, none of the regulators held, not even the one from the Gas Company, the only appliances that were affected were ones with pilot lights. The reason I mention this is what would be the point to add extra regulator if the unit has one and there's one from the Gas Company, adding "extra" regulators wont do anything, if you get too much pressure no regulator will hold.
I think the other regulator they're talking about is probably the one from the Gas Company. Side note: The Gas Company paid for all the furnaces that were effected and cleaned the ducts, must have been one hell of a bill, now you know why gas has gotten so expensive. It's to cover their ***** ups. I do have a question, what other gas is there, aside from LP, that's not from a Gas Company? Last edited by mickeyco; 02-14-2007 at 06:37 PM. |
#6 | |
Re: Gas RegulatorQuote:
Trade: Gas fireplace
Re: Gas Regulator
Call a gas fireplace professional. I recently got a call from a homeowner that his complaint was "odors" coming from his fireplace. Well, the "odor" was gas coming from the control valve where he installed a flair fitting in where a pipe fitting was suppose to be........this "odor" has been there since he installed it 18 months ago !!!!! His little oversight could have blown up his $750,00 home.
| Co2 air tanks | RobertCDF | Tools & Equipment | 14 | 03-12-2009 09:27 AM |
| CO 2 powered nailgun | RobertCDF | Tools & Equipment | 36 | 09-08-2008 07:59 PM |
| Squeaky regulator | Leo G | HVAC | 0 | 04-05-2006 01:36 PM |
| HVLP gravity feed setup and techniques | cblevesque | Painting & Finish Work | 5 | 08-01-2005 11:31 PM |
