Garage Insulation
I am finishing a basement with a tuck under garage so the the space above the garage is finished/heated already. The roof of the garage is insulated and sheet rocked (which I plan to redo). The walls of this tuck under garage are block and are not insulated. The question is should I insulate the walls? Glue some rigid foam to them or something? The exterior walls of the garage are about 50% above grade.
Trade: H.V.A.C Contractor
Re: Garage Insulation
This would depend on what you plan to use this space for. If you plan on using it for an office or extra rec area then sure I would insulate it. If you just using it to store general stuff save the extra money.
"Air conditioners are like eggs they are cheaper in the country." |
Trade: Renovations
Do you want a heated garage? Is that what you're asking? If so, then insulate it.
If all you are trying to do is keep the living space above the garage warm then you have already done that. Insulating the walls of the garage will have minimal effect on the livability of the space above given that the floor/ceiling is insulated.
| Garage receptacle | ChuckEA | Electrical | 21 | 04-27-2011 07:45 PM |
| Would You Install Insulation in the Garage? | Hages | Construction | 7 | 01-29-2007 12:36 AM |
| Flat roof over garage leaking under exterior walk out door | IHI | Roofing | 18 | 05-30-2006 10:28 PM |
| ...continued...garage floor drain progress | carlspackler | Plumbing | 0 | 05-27-2006 02:54 PM |
| Interesting attic insulation findings | IHI | General Discussion | 5 | 02-28-2006 02:22 PM |
