If you are worried about fumes and vapors being an ignition hazard, you could go with a 90%+ unit that uses outside air for combustion and has a sealed burner box or even a small package unit that sits beside your garage with only the ductwork being inside the garage area. They also have small PTAC's ( Package Terminal A/C's) that are heat pumps and are like a large window unit you could mount through the wall. With the heat pump, you could get it without the electric strip heat. In any case, remember filters filters filters.
