Furnace Won't Stay Running
Old 02-12-2008, 03:45 PM   #21
AngusII's Avatar
Trade: Residential HVAC
Send a message via MSN to AngusII
Re: Furnace Won't Stay Running
Leo,
Follow the same steps as above especially the flame sensor part and report back.
AngusII is offline
Old 02-14-2008, 04:31 AM   #22
Leo D's Avatar
Trade: Engineer Hotel
AngusII,
I cleaned sensor but also noticed a resistor loose too. But it has worked for almost a day without a problem. I didnt resodder the resistor but wiggled it. Thanks for your help.
Leo D is offline
Old 02-25-2008, 09:20 AM   #23
big waynester's Avatar
Originally Posted by vlux View Post
dont mean to be rude but you dont know what youre doing, we said jump the red and white wire, not red -yelow. dont blow yourself up or we all loose
sorry typed wrong colors,I put in a new dig programable T stat and so far no problems.
big waynester is offline
Old 03-08-2008, 05:43 PM   #24
IRISHADAM711's Avatar
Trade: HVAC/R, BUILDER
I agree you need to know the operations of a furnace to service them....Get your meter out and start searching for an open switch when it first fails... Look at the limit control first, maybe its weak from years of dirty filters and cutting out prematurely, check the roll out switches (some dont have manual resets) did anything change in the system ductwork? maybe not enough return anymore or heck even check the filter... thermstats are always blamed and normally not the problem. The flame rod you said was cleaned so forget about it or meter it ( should be at least 2.0 or better.
IRISHADAM711 is offline
Quality of Payne furnace ??? Home Pro HVAC 45 03-30-2010 10:10 PM
What is everyone running for Fiber in new home Construction? voiceguy Low Voltage 9 04-09-2008 06:20 PM
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-29-2008 12:05 AM
Goodman 80% furnace won't start with side cover on rlelliott HVAC 7 12-09-2007 12:42 AM
Forced Air Furnace w/Air Heat Pump Backup mahleumon HVAC 1 03-14-2006 10:15 PM
