Furnace Vent
Old 06-25-2008, 07:58 PM   #1
mikec's Avatar
Trade: remodeling contractor
Furnace Vent
I have an oil fired hot air furnace in my house. The problem is there is a center chimney that reall f's up the living room. Adding a side wall chimney doesn't seem to be an option.
I have seen zero clearence furnace vents. I think thats what they're called(just a vent sticking out of the wall). Can any furnace be converted to this system? Or just gas fired?
mikec is offline
Old 06-25-2008, 09:45 PM   #2
mdshunk's Avatar
Re: Furnace Vent
You can put a power vent kit on your oil furnace to sidewall vent it. While it's not a common thing to do, it is sometimes done as a cheaper alternative to a failed chimney. You need to re-do the Bacharrach after you install a power venter on your oil burner.
mdshunk is offline
Old 06-26-2008, 07:41 AM   #3
Tom M's Avatar
Re: Furnace Vent
You have to read your appliance specs to see if it can be converted to a fan assisted direct vent. If you have a center chimney I guess your equipment will also need to have a long connector to reach the side wall. There are limits to L vents and connector lengths as well as clearance on those ducts. Also there are strict rules about terminating the exterior wall. This oil furnace smell bad and leave residue anywhere within six ft of the ground.
Tom M is offline
Old 06-26-2008, 08:28 PM   #4
mikec's Avatar
Re: Furnace Vent
Thanks guys, looks like we'll live with the center chimney
mikec is offline
Old 06-28-2008, 07:58 PM   #5
westernhvac's Avatar
Trade: HVAC Contractor
Re: Furnace Vent
is there natural gas available in the area and by the way, you might even be doing your customer a favor by suggesting electric strip heat in the current oil pricing atmosphere.
westernhvac is offline
Old 07-01-2008, 05:54 AM   #6
mikec's Avatar
Re: Furnace Vent
I'm Not sure about gas lines. Can the oil burner be converted to gas? Is this expensive? Its not a customer house, its mine!
mikec is offline
Quality of Payne furnace ??? Home Pro HVAC 45 03-30-2010 10:10 PM
seal gable vents after ridge vent installed? tacoma5050 Roofing 26 01-18-2008 10:50 PM
furnace venting earl964 HVAC 4 09-11-2007 09:19 PM
Maybe it's a good time to upgrade furnace ron schenker HVAC 4 03-02-2007 12:11 PM
Fresh air vent in ducting? carlspackler HVAC 6 12-03-2006 05:59 PM
