Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 01-29-2004, 02:39 PM   #1
Unregistered
Guest
Trade:
Posts: n/a
Unhappy Furnace Switch Problem
Hello,
I just had a HVAC company come out and look at my Heating unit. The problem is the heater keeps tripping the breaker. They looked at the unit and said that I need a new Furnace Switch and they don't fix those we have to talk to an electrician. Is this true? How much should I expect to pay? Is this something that I could do myself? This house is only 3 years old is this normal?
Help!
Old 01-30-2004, 06:21 AM   #2
Bjd
Trade:
Which switch are they talking about?
Bjd is offline   Reply With Quote
Old 01-30-2004, 07:56 AM   #3
Trade:
My guess is the poster is talking about a breaker for an electric heat unit. Not a furnace. These slam bam DIY homes probably have one #10 wire pulled to the air handler trying to serve 15 kw. Then wonder why a 30 amp breaker trips.
Steve Wiggins is offline   Reply With Quote
Old 01-31-2004, 05:51 AM   #4
Bjd
Trade:
That will make a bang when she trips
Old 02-03-2004, 01:03 PM   #5
Awaiting Email Confirmation
Trade:
Location: Southern Maryland about 25 miles south of Washington D.C.
I had a similar problem a few years back. It seems the air handler in th attic space (two zone house) was wired direct to the unit with aluminum wire. The problem was the aluminum wire generated to much heat during the heat cycle thus throwing the breaker in the unit. Reset the breaker and the unit would run for a day or two or sometimes less. The fix=Run aluminum wire to new disconnect located near unit in attic. From disconnect run copper wire directly to unit. Not a problem anymore.....Billy
Itsahipo is offline   Reply With Quote
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-28-2008 11:05 PM
carrier gas furnace problem mjm0073 HVAC 4 01-30-2007 11:34 AM
smart light switch circuit toastermaker Electrical 7 12-07-2005 11:45 PM
goodman furnace roll out switch problem mme HVAC 9 02-10-2004 08:20 PM
