Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 11-12-2005, 12:17 PM   #1
Trade: Flooring
Unhappy Furnace not working
I have a Bryant Furnace (1980).It went out just before summer and I had someone come out to look at it. They said the Pilot Assy. was bad, I replaced it with the 3 wire pilot safety switch.It worked perfect for 2 1/2 days then back to what it did before. The ignitor sparks the flame, the flame burns for about 15-20 seconds. Then when it seems like it's supposed to go to the burners , it goes out.Then a knock (like a knuckle hitting the metal), flame lights , then goes out. It keeps repeating this but nothing else happens.Could it be the Gas Valve has gone bad ? Any help is appreciated. It's getting cccccold in here.
TheBillman is offline   Reply With Quote
Old 11-13-2005, 10:11 AM   #2
Trade: HVAC Service Technician --RSES CM-- NATE Certified
It could be the gas valve it could also be a gas pressure drop also. Gages need to be connected to the inlet of the valve to measure pressure while it operates. If the pressure drops you have a gas problem. If it doesn't the valve is bad.
MechAcc is offline   Reply With Quote
Quality of Payne furnace ??? Home Pro HVAC 38 09-29-2009 09:42 AM
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-28-2008 11:05 PM
Maybe it's a good time to upgrade furnace ron schenker HVAC 4 03-02-2007 12:11 PM
Heil Two Stage Furnace Not Working Unregistered HVAC 1 04-30-2004 05:35 AM
