Furnace Flame Blow-Out
Old 10-21-2004, 02:56 PM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Question
Working on a 14 year old Clare horiziontal Megasave LPG furnace. Intermintently, flame starts and immediately "poofs" out, then may re-start and run ok. Occasionally gas will shut off for no apparent reason after unit has been running for a few minutes then cycles right back on. Incoming and manifold pressures check ok; replaced power vent motor assembly which was very hot and noisy, pressure switch replaced, and installed new step-up gas regulator. Checked intake and output vent pipes -- ok and clear. No change to problem. Have checked every system I can think of. Any ideas?
Old 10-21-2004, 07:31 PM   #2
Unregistered
Guest
Posts: n/a
Re: Furnace Flame Blow-Out
Also, the ignitor appears to be working ok.
Old 10-22-2004, 06:01 AM   #3
Bjd's Avatar
Jeez, make you want to think. Could be a lot of things, any saftetys tripping durning the "Break Dance" of the gas valve.
If not try the valve power during the dance and see if the power is dropping out. Could be the valve.
What type of control board are looking at?
Bernie
Bjd is offline
Quality of Payne furnace ??? Home Pro HVAC 45 03-30-2010 10:10 PM
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-29-2008 12:05 AM
Flame Sensor darren HVAC 2 01-16-2006 01:28 PM
Furnace not working TheBillman HVAC 1 11-13-2005 10:11 AM
Furnace Cycling reddog HVAC 9 11-04-2005 09:31 PM
