banctecbobn
Guest
Posts: n/a
Furnace Blowing Hot And Cold Air
Have a Goodman 92k two stage gas furnace.
While cleaning out the furnace I noticed different temperature air blowing directly out the top of the furnace. I didn't take any temp readings but there is definately a difference when moving your hand across the entire area. Is this normal or is there an issue that should be addressed????????? All the burners are burning. |
Dr Heat
Guest
Posts: n/a
Re: Furnace Blowing Hot And Cold Air
Not a problem you are just feeling air that has not mixed together.
in 90% furnaces the air passes through the secondary then the primary. The primary is narrower than the secondary so some air passes on the side not being heated till it mixes. |
