Furnace Blower Does Not Start
I need some diagnostic help with my Luxaire Furnace.
My problem: The furnace blower will not come on after the burners have completed there cycle. I tested the fan limit switch and all other limits and they all check out ok. There is a red LED light inside the furnace that flashes one time. According to the chart in the furnace, it says “Lockout Check Furnace”. Someone suggested that I turn the switch power going to furnace on and off quickly and the lockout will reset it self. It did not work. What else can I do? Help! Freezing in Michigan. Paul |
Re: Furnace Blower Does Not Start
If your stat has a "fan-on" position switch to that so you won't freeze till a technician can get there to diagnose the problem. If you have a fairly new Luxaire furnace you might as well get braced for a new circuit board. They have been dropping like flies in my area.
#3 | |
Re: Furnace Blower Does Not StartQuote:
My stat does have a fan on position - it will not start the blower motor. I disconnected the leads to the fan and wired them to a cord and run the fan that way. There is one thing that I did not mention - When I was replacing my furnace filter, half of it was gone. Could it have pluged up my air flow? There is no bind in the motor and the blower wheel turn easily. Thanks for help Paul |
Did this problem start after the filter replacement? If so check to see if you may have upset the groung for the control board. These boards require that they be grounded to the chasis of the unit, be sure to check this from the 12 pin connection the wire would be green, make sure that it has a good ground.
bjd |
#5 | |
Paul |
#6 | |
Paul |
Unregistered
Guest
Posts: n/a
If you didn't find the other half of that filter, your other problem will be a blower motor. I recommend pulling the blower and making sure the vames on the wheel are un obstructed
| Quality of Payne furnace ??? | Home Pro | HVAC | 45 | 03-30-2010 10:10 PM |
| Goodman 80% furnace brand new won't start | Hguy | HVAC | 21 | 03-29-2008 12:05 AM |
| Goodman GMT045-3 Blower problem | GaryStevens | HVAC | 2 | 02-23-2007 12:17 AM |
| Gas Furnace overheats - fan does start | Pauly | HVAC | 2 | 11-28-2005 12:49 AM |
