Trade: general
Furance Cleaning
We want to have our furnace cleaned and inspected. Some places call this a tune-up. This would be an annual cleaning etc. What should we expect from a furnace "tune-up"? What exactly is done, or should I rephrase that to What Exactly NEEDS to be done annually to insure a proper working furnance and to have it last for years.
skippy |
The Doctor is In!
Trade: HVAC owner
Re: Furance Cleaning
Alot depends on the company doing it and the type/age of furnace. Here are just some of the things we do on ours. Mind you, this is strictly gas furnaces:
Remove and clean burners Remove and clean pilot Clean flame sensor Replace thermocouple Remove and oil blower motor Vacuum off blower housing and wheel (remove and clean blower wheel if extremely dirty- extra charge) Vacuum out blower compartment and heat exchanger cells Vacuum out secondary exchanger ( 90%+ models only) Inspection of heat exchanger by camera Run furnace and check safeties, gas pressure, and temperature rise. Adjust burners if needed Check draft on furnace Inspect flue pipe for rust, broken joints, or blockages Check drains and traps (90%+ models) Perform CO check during run cycle ( using combustion analyzer to verify performance) Service humidifier (pad and labor extra) Replace filter(s) or clean EAC cells and inspect (High efficiency Spaceguard/Air Bear filters extra) Replace thermostat batteries (digital only) Level thermostat Check heat anticipator setting (mercury bulb stats) We don't do 20 minute $49.95 specials. We charge $150 for this and are there for about an hour to hour and half. |
| Roof cleaning | Barry M | Roofing | 33 | 09-26-2011 01:36 PM |
| Drain cleaning | Moonray | Plumbing | 14 | 12-25-2009 11:41 PM |
| Estate Cleaning | kpsservices | General Discussion | 6 | 04-07-2007 08:13 PM |
| drain cleaning | the_turd_man | Plumbing | 13 | 02-07-2007 05:26 PM |
| Cleaning Smoke Stained Masonry | Brickie | Masonry | 11 | 09-07-2006 11:23 AM |
