#21 |
Trade: HVAC
Re: Fujitsu Problem
On a 25' vertical drop to evap. The pressure in the line at the evap will be 12.5 PSIG higher then at the condenser(this is for liquid lines).
So it may be over feeding in all weather conditions. Just more predominant in warmer weather. When the head pressure is higher at the TXV in the OD unit. You may have an oil problem. Is there an inverted trap. Or some other sort of rise in the line, to prevent oil from siphoning out of the condenser. |
| The Following User Says Thank You to beenthere For This Useful Post: | A.D. Const (05-26-2009) |
#22 |
Trade: HVAC
Re: Fujitsu Problem
I have seen a lot of stats get thrown off with heat coming off of servor room equipment causing the units to freeze up. Is the remote in a good location?
#23 |
Trade: A.D. Contracting & Remodeling LLC.
Re: Fujitsu Problem
Yes, we normally hang it by the unit.
| Paslode Problem | HomeWS | Tools & Equipment | 6 | 03-02-2009 10:32 PM |
| trane gas furnace problem | funcky | HVAC | 7 | 01-28-2009 01:51 PM |
| Hot water problem | PLUMBINGITALL | Plumbing | 7 | 01-24-2009 11:15 AM |
| Toilet problem | Mike Finley | Plumbing | 5 | 11-06-2007 10:21 AM |
