Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 02-12-2007, 06:36 PM   #1
mdshunk's Avatar
Which fuel is cheapest?
I just ran these numbers (my local prices) for a user on another site. It was a pain in the neck to derive, so I thought I'd post them here as well. I'll break the prices down in terms of therms, which is 100,000 BTU's. (prices in my chart include distribution and taxes)
Natural gas - $0.0145 / ft³, 1ft³ of natural gas is 1,031 BTU, that makes natural gas $1.40 per therm.
LP gas - $1.45 / gal, 1 gal of LP gas is 91,500 BTU, that makes LP gas $1.59 per therm
Heating oil - $2.30 / gal, 1 gal of heating oil is 138, 690 BTU, that makes heating oil $1.69 per therm
Electric resistance- $0.09 / Kw/h, 1 Kw/h is 3,412 BTU, that makes electric $2.64 per therm
Plug into that some common efficiencies for heating equipment, and you'll get your net price per therm.
Consider a modern Natural Gas or LP gas furnace to be around 90%, an oil furnace 85%, and electric resistance is 100%. That gives you typical net operating prices, per therm, as follows:
Natural gas, $1.55/therm
LP Gas, $1.76/therm
Oil, $1.99/therm
Electric resistance, $2.64/therm
EDIT... I just ran the current numbers for PA hard coal and several of the more popular central PA fuel wood species, if anyone cares for that data as well.
mdshunk is offline   Reply With Quote
Old 02-12-2007, 10:17 PM   #2
Trade: general contractor - SFR
In my mixed climate and warmer areas, we see a lot of heat pumps. Since they basically just transfer heat instead of generating it, they run about 40-50% cheaper than electrical resistance and are used as A/C as well. With no flues, they're also the cheapest central system to install. Auxiliary electric coils kick in when it dips below freezing, but the brief spike in $ is more than offset by the efficiencies in the rest of the year. We still have a lot of natural gas and propane systems, too. Don't see much coal or oil, though. I guess it all depends on local environmental conditions and location to fuel sources.
"How much per sq.ft? Well.. gimme $1K and I can build a shed. Gimme $1M and I can build the same size shed with gold plating and encrusted diamonds."
georgia dawg is offline   Reply With Quote
Old 02-13-2007, 07:54 AM   #3
Trade: Plumbing and heating
Hey MD , nat. gas is measured in cubic feet not square feet.
PIPES is offline   Reply With Quote
Old 02-13-2007, 09:06 AM   #4
Custom Builder
Glasshousebltr's Avatar
My natural gas and my feet are measured in Nasal Units.
Bob
Bob
Glasshousebltr is offline   Reply With Quote
Old 02-13-2007, 05:23 PM   #5
mdshunk's Avatar
Thanks. Fixed it.
Old 06-01-2009, 01:31 PM   #6
31b
Trade: electrician
MD, are those numbers still pretty much the same? obviously the different in burning power doesn't change between LP or NG, but what you calculated also used the price per cubic foot of NG at the time and price per gallon of LP I guess too. Not sure if one or the other's pricing has changed significantly since.
I'm about to switch over to one of those utilities, just ripped out my old oil system, and was quoted $3300 to get a NG line and meter brought to the house. Propane isn't going to cost me much at all to get installed, so now I'm trying to run some numbers on whether it's going to be justified to spend a few grand and how quickly will it be saved in the end, or on resale of the house, etc.
31b is offline   Reply With Quote
Old 06-01-2009, 08:41 PM   #7
Trade: HVAC
What MD didn't post. is what it cost to rent the LP tank.
If you rent the tank, you are charged a rental fee on each gallon delivered. Todat, that rental fee can be as cjeap as 25 cents per gallon, to over 1 dollar a gallon.
So, are you going to buy your own LP tank, or rent it?
If renting it. Fine out how much they charge.
beenthere is offline   Reply With Quote
Old 06-03-2009, 09:22 AM   #8
Holt, MI
Trade: HVAC
31b,
Add into the equation, the cost of replacing the equipment sooner if you use LP. It is hard on furnaces and their failure rate is often sooner. I have removed furnaces as young as 7 years old, which were just burned out. In some cases, the heat exchangers are plugged from running out of fuel and the customers wanted the quickest way to heat, which was replacement.
Larry
Bestheating is offline   Reply With Quote
Old 06-03-2009, 09:24 AM   #9
Trade: HVAC
LP installs sgould have a LP cut switch installed to protect them from being operated like that.
They will last much longer
Old 06-03-2009, 10:01 AM   #10
Holt, MI
Trade: HVAC
Yes on the cutoff switches but that has not always been the case. Either way, I would pay to have natural gas brought to my home if possible before installing an LP unit if at all possible.
Larry
Old 06-03-2009, 11:11 AM   #11
Trade: HVAC
The most trouble from LP systems. Comes fdrom those that were not installed properly.
No LPS. Didn't use the SS burners. Didn't bother to set up combustion.
If installed properly. Never had any go out any faster then a NG one installed in the same way.
Old 06-06-2009, 08:18 AM   #12
Trade: HVAC Service Technician --RSES CM-- NATE Certified
You can down load a Microsoft XL program from the DOE that will calculate costs for natural, propane, wood, corn pellets, coal, etc. at
www.eia.doe.gov/neic/experts/heatcalc.xls
MechAcc is offline   Reply With Quote
Hitachi NR90GR & Paslode Fuel Cells? AlbertZeroK Tools & Equipment 11 11-19-2007 05:15 PM
Fuel supplier loyalty rino1494 Excavation & Site Work 9 02-05-2007 10:56 AM
Fuel Tank Condensation denick Excavation & Site Work 3 05-26-2006 08:29 PM
Plans for this summer and "expected fuel costs" IHI General Discussion 27 04-20-2006 06:45 PM
fuel chrisherk Excavation & Site Work 8 02-01-2006 12:32 AM
