Fresh Air Duct Work For Oil Furnace
Old 12-06-2010, 08:33 PM   #1
3Rivers's Avatar
Trade: Jackass of all trades
Question
I've only seen this on the oil furnace in my home. I have a Bryant forced air oil furnace (beckett burner). First, the exhaust ducting exiting top center has a damper on it before exiting the home but it is inside a sheet metal box that has a fresh air supply from duct work leading outside. ALSO, the right side of the furnace housing has duct work attached to supply fresh air to the burner/pump area right behind the front removable cover of the furnace. When the furnace isn't running, cold air pours in from the fresh air ducting on the right side of the furnace which chills the basement and you can actually fell the cold air coming through the supply vents when the furnace isn't running. Do I need all this fresh air supply crap? I haven't seen this on any other furnace on any of my jobs. Thanks.
3Rivers is offline
Old 12-06-2010, 10:09 PM   #2
Carbon Dioxide Producer
DuMass's Avatar
Trade: EC
Re: Fresh Air Duct Work For Oil Furnace
Sounds like a direct vent oil furnace, so without seeing it, I would wager that intake duct likely has to stay.
But, since the burner gets its combustion air from outside, maybe you could try to enclose the equipment by building a small insulated utility room around it. That might help keep the rest of the basement from getting cold anyway. Just be sure to leave enough room to clean and service the equipment.
DuMass is offline
Old 12-06-2010, 11:37 PM   #3
3Rivers's Avatar
The exhaust is 6" round metal ducting directly from the combustion chamber to the chimney. It first goes through the sheet metal box which contains the damper door and a fresh air duct (same size). The other is also 6" metal ducting attached to the side of the furnace housing and it leads directory outside. Some major cold air comes in the 6" duct attached to the side. It just looks odd......really odd.
3Rivers is offline
Old 12-07-2010, 05:26 AM   #4
beenthere's Avatar
Trade: HVAC
Rewards Points: 1,084
Post pics of this set up.
beenthere is offline
Old 12-07-2010, 07:38 AM   #5
3Rivers's Avatar
I was thinking that would be the best way to show everyone my setup. I'm working on the pics now.
3Rivers is offline
Old 12-07-2010, 08:10 AM   #6
DuMass's Avatar
Trade: EC
Yes, post a pic.
Most oil direct vent [ODV] equipment doesnít use PVC, they use metal duct, but anyway, you said in your second post that the pipe goes into the "chimney". If you have a chimney, I donít know why you would have a direct vent system with a fresh air intake.
DuMass is offline
Old 12-07-2010, 08:19 AM   #7
3Rivers's Avatar
My thoughts exactly. Pics coming shortly. Thanks.
3Rivers is offline
Old 12-07-2010, 09:00 AM   #8
3Rivers's Avatar
Ok, it is a Bryant model# 369AAN Multi-Poise furnace. The picture in their brochure shows one round metal duct venting the exhaust straight up......thats it. No fresh air ducts anywhere.
3Rivers is offline
Old 12-07-2010, 09:06 AM   #9
3Rivers's Avatar
3Rivers is offline
Old 12-07-2010, 09:10 AM   #10
3Rivers's Avatar
The duct in the TOP of the "damper box" is a fresh air lead from outside. The horizontal duct exiting the left of the box goes directly into the chimney. The right side duct is a fresh air supply connected to the same box outside as the other fresh air duct. Pic to follow.
3Rivers is offline
Old 12-07-2010, 09:13 AM   #11
3Rivers's Avatar
3Rivers is offline
Old 12-07-2010, 09:23 AM   #12
3Rivers's Avatar
3Rivers is offline
Old 12-07-2010, 10:20 AM   #13
DuMass's Avatar
Trade: EC
It looks like when the furnace was specíd by the installer, they must have decided that the building envelope was tight and they needed to use the outside combustion air setup. Doesnít this vent setup indirectly provide makeup air for the plenum as well?
I wouldnít just start modifying any ducts without having somebody qualified out there to look things over first.
DuMass is offline
Old 12-07-2010, 10:44 AM   #14
3Rivers's Avatar
They just reattached what was there feom the old furnace. The old furnace always had a soot smell which ended up being a crack in the exchanger. Maybe thats why there was a carbon monoxide detector in the basement when I bought the house. The basement is not tight by any means.......definitely drafty.
3Rivers is offline
Old 12-07-2010, 06:27 PM   #15
beenthere's Avatar
Trade: HVAC
Its a combustion air intake.
If your basement is not tight. then closing off the combustion air intake is ok.
Looks like someone had plans to finish the basement. And they set it up for a tight basement in the future.
Looking for work southern dutchess county NY "JJ" Help Wanted or Looking For Work 1 05-25-2010 02:03 PM
Looking for work.... THINKPAINTING General Discussion 2 02-10-2010 03:42 PM
Furnace rebate contractor problem??? TIA rodnig1 General Discussion 1 12-09-2009 02:56 PM
State work and requirements J-Peffer Business 2 01-26-2009 01:23 PM
Looking for ideas for insulating craw duct work. Veith@toast.net HVAC 15 01-21-2009 07:34 PM
