Forced Air Systems
Old 08-15-2006, 11:23 PM   #1
ryan80's Avatar
Trade: GC Superintendent
Forced Air Systems
I am building a new construction residential home. I just started as the super yesterday. Already i see hundreds of problems. It seems that no one has thought out what is coming next.
I am going to have a problem getting my AC ductwork through some tie beams. I heard about forced air AC systems. I understand that they force high velocity air through PVC pipe or something of the kind. Does anyone know anything about this?
Thank you,
ryan
ryan80 is offline
Old 08-15-2006, 11:28 PM   #2
mdshunk's Avatar
Re: Forced Air Systems
Yep, they are called Unico or SpackPak systems. They use small diameter, high velocity ducts and a special associated air handler. These systems need engineered, not simply installed. The HVAC supply house will often commission the factory rep to do this for you, per your print.
mdshunk is offline
Old 08-16-2006, 06:48 PM   #3
workman's Avatar
Trade: general contractor
Good Luck!
workman is offline
Gravity drainage basement systems skidmark845 Construction 5 08-01-2007 10:22 PM
Pacific Laser Systems.. Ryan03 Tools & Equipment 2 07-29-2007 10:42 PM
CCTV Digital Security Camera Systems 3rdEyeSecurity General Discussion 1 05-01-2007 02:09 PM
Septic systems in Florida MinConst Plumbing 7 02-07-2007 10:36 PM
Furnace-gas forced air- high pitched noise saturn711 HVAC 3 03-25-2006 09:52 PM
