Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 12-02-2008, 04:23 PM   #1
Trade: carpentry
Foil tape question from a carpenter...
Help a wood chipper out, please.
Can I use UL-723 ("rated for flame spread and smoke development") tape in place of UL-181-AP foil tape to wrap the seams in the venting for a pellet stove (this is in my own home)?
Thanks.
Jeremy E is offline   Reply With Quote
Old 12-02-2008, 08:08 PM   #2
Trade: H.v.a.c.
If its rated for flame spread and development, it probably would be ok, but can't you get info from the manufacturer to find out what they reccomend? You can't go wrong by their way.
flashheatingand is offline   Reply With Quote
Old 12-03-2008, 12:30 AM   #3
#1 stunner
Trade: Design/Build
Send a message via AIM to Static Design
Thanks.
I believe the main difference is the fire rating, I think the 181 has a resistance of around 30 mins and 723 is not as superior (contact manufacture for verification). I don't see any problem using the 723 in its places since you are just venting, I assume.
Static Design is offline   Reply With Quote
Old 12-03-2008, 08:37 AM   #4
Trade: carpentry
Thanks, guys. I also assume that the UL 723 is sufficient, but I ran out to get a roll of the UL 181 last night. Why tempt the inspector?
Thanks again.
Jeremy
Old 12-26-2008, 12:19 AM   #5
Dr Heat
Dr Heat's Avatar
Trade: hvac
this needs to be 181a not 181b or a/b
Dr Heat is offline   Reply With Quote
Old 12-26-2008, 08:46 PM   #6
Trade: Lighting automation
Doc, what's the difference between the a & b? Is the 'b' o.k. for taping reflective insulation?
Thanks.
V
delta l is offline   Reply With Quote
Old 12-26-2008, 09:52 PM   #7
Hearthman's Avatar
Trade: chimney inspector, consultant, and contractor
Exclamation
Foil tape listed to UL 181 A-P is designed and tested for sealing duct board. 181-B-FX tape is designed for flexible duct transitions. The 181 listing includes the UL 723, which is also the ASTM E-84/ NFPA 255 Steiner Tunnel test for flame spread. For instance, type X drywall rated at a flame spread of '15' propagates a flame front 15% as fast as red oak in the tunnel test. But it still burns, therefore it is considered 'combustible' by code stds.
You do not wrap pellet vent with tin tape. You seal the joints with red RTV per the listing.
HTH,
Hearthman
Keep the fire in the fireplace!
Certified Fireplace Inspector & Master Hearth Professional
UL Standards Technical Panel 103
BoD HPBA & International Assn. Fireplace and Chimney Inspectors
Hearthman is offline   Reply With Quote
Cost Plus Question randybelk@comca Business 16 09-11-2008 09:09 PM
Sewer Infrastructure Question ABLE1 Excavation & Site Work 20 05-28-2008 10:05 AM
Loose Drywall Tape hanover Drywall 6 06-23-2007 02:01 PM
