be careful,there are a lot of homes that are already lacking return air.
lack of return air can be the cause of quite a few problems, for instance:
-furnace cycling on faceplate limit (getting too hot)
-air conditioning coil icing up and slugging liquid to compressor(not enough air flow)
Have your furnace and air clean and checked to make sure that your system isn't lacking return air now. otherwise I recommend finding a way to get that 7" return back into the hallway. (do not put the return in the bathroom to avoid letting the whole house smell you duece
