Flame Sensor
Old 01-13-2006, 12:14 PM   #1
Electrical Apprentice
darren's Avatar
Trade: Electrical
Flame Sensor
Hello
I have a Lennox furnace(not sure of the model number, can be found if needed) but every year about this time it acts up and by reading the flashing lights it says to check the flame senser. So i pull the flame sensor out sand it and take off the blue markings(to make it look like new), put it back in and will work good for another year.
Is this a normal thing to do with a flame sensor and how many times can i do this with out ruining the flame sensor.
Thanks for your help
Darren
darren is offline
Old 01-13-2006, 07:33 PM   #2
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
Re: Flame Sensor
Depends on the air quality where the furnace is located. High chemical (laundry rooms) or damp areas (leaky basement) can cause flame sensors to become dirty. Impurities in the gas delivered can also be a factor. Manufactures are now recommending using a fine steel wool over sandpaper due to the silica content and residue left on the sensor.
HVAC Doc is offline
Old 01-16-2006, 01:28 PM   #3
Holt, MI
Bestheating's Avatar
Trade: HVAC
Re: Flame Sensor
Doc's advice is good, but let me add the following thought. Flame sensors read the current from the actual sensor to the nearest ground. The connection is the gas itself. When the flame sensor is cleaned, the job is only half done. In your case, I suspect you may have an integral pilot assembly and the sensor is sensing the pilot flame. The other application is to sense the main burner flame. In either case, a good clean ground is of utmost importance. Take out the pilot assembly hood, or ajacent burner, whichever is the case and brush it with a wire brush. Also, if it is the pilot sensing type, make sure the pilot orifice is clean and giving you a good flame. This is quite common. Flame sensors are not that expensive, and I have been replacing them more often lately. Cleaning them is not always effective.
Larry
Bestheating is offline
need furnace expert - Goodman furnace DMC HVAC 22 02-19-2009 01:24 PM
Hi tech sensor ron schenker Masonry 1 06-12-2006 10:57 PM
GMPN100-4 coil red/no flame Brandon Hook HVAC 2 03-10-2005 03:04 PM
Goodman Gmp flame problems Tim Geiger HVAC 1 02-05-2005 09:15 AM
Furnace Flame Blow-Out Unregistered HVAC 2 10-22-2004 06:01 AM
