Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 12-04-2008, 09:07 PM   #1
joasis's Avatar
Fireplace insert?
I have only seen one of these, and it doesn't have a brand, but would anyone have an idea of who makes a fireplace that has a bottom ash grate and cleanout from outside? The one I saw has a cast door outside in the base of the fireplace, and can be cleaned without having to shovel ashes inside the home. Ideas guys?
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
405 314 5802
joasis is online now   Reply With Quote
Old 12-04-2008, 10:06 PM   #2
cleveman's Avatar
Trade: custom home building
Check with the fireplace shops. I assume you're looking at a retrofit. Obviously they are to be avoided except for retrofits because you're building a fireplace and then putting a stove inside it.
Heatilator (heat it later) may have one.
All this stuff really skyrocketed in cost. You may expect to pay over $1500 for a decent unit.
cleveman is offline   Reply With Quote
Removal of fireplace insert Tscarborough Masonry Picture Post 8 11-10-2007 10:38 PM
reinforce floor for fireplace insert install 72chevy4x4 Framing 3 09-09-2007 02:22 PM
Fireplace Insert Raised off the Slab Hambone Masonry 14 04-22-2007 08:54 PM
Fireplace Insert Raised off the Slab Hambone Construction 7 04-20-2007 10:57 PM
Electrical for fireplace insert Mike Finley Electrical 22 05-13-2006 09:26 AM
