Extremely Basic DIY Steam Question.
Old 11-10-2017, 04:49 PM   #1
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 7,204
Gas fired steam system with radiators of varying vintages.
Room A is too cold.
Room B is too hot.
Adjust petcock settings and rooms will balance out?
Easy Gibson is online now
Old 11-10-2017, 07:17 PM   #2
tjbnwi's Avatar
Rewards Points: 3,410
Re: Extremely Basic DIY Steam Question.
Single pipe system or dual pipe system?
If it's a single system open the petcock on A, this will let air out, allowing more steam in. Add air to B (really just leave it alone unless it's unbearably hot).
Dual pipe, adjust the Lockshield valve.
Be very careful letting the air out on A, the latent energy of steam can peel skin right off the bone.
tjbnwi is offline
Old 11-10-2017, 07:27 PM   #3
Single pipe.
That's what I figured. Wasn't sure if I should adjust other rooms down to compensate. I guess there's plenty of steam to go around.
Old 11-11-2017, 10:03 PM   #4
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,341
partially cover the "hot" radiator till the room is comfortable? Install a air vent and thermostatically controlled small fan to move the hot air to the cold area if they are contiguous... louvered door(s) maybe.
Wrap all the pipes with fiberglass insulation to the 'cold' room.
Reduce heat loss in cold room... Storm windows etc...insulate attic space.
Goggle single pipe steam heat adjustments.... really...
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
Rio (11-18-2017)
Old 11-18-2017, 07:50 PM   #5
Storms and insulation are next up. Kind of going room at a time and haven't gotten to that one yet. Hoping I could do some slight of hand to get through this winter, then properly address everything before next year.
Old 11-20-2017, 03:28 PM   #6
hdavis's Avatar
Rewards Points: 8,925
Make sure to drain any water before messing wth the rest.
hdavis is online now
Stupid question? Anyone ever mix sodium bicarbonate with recycled glass? MasterBlaster Sandblasting 7 03-23-2013 06:14 PM
Insulating attic question power Insulation 19 03-10-2013 07:55 PM
Vinyl Flooring Adhesive Question josephdan General Discussion 1 03-05-2013 04:36 PM
Help quoting a steam showe installation. aulona Remodeling 3 06-15-2012 10:22 PM
