Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 06-20-2009, 08:54 AM   #1
loneframer's Avatar
Trade: residential framing/general carpentry
Extreme AC
This Unico system is being installed in the house I'm working on. I don't know too much about it, but it looks like it should be in the space shuttle.
" It's a Jersey thing, you wouldn't understand"
loneframer is online now   Reply With Quote
Old 06-20-2009, 09:00 AM   #2
loneframer's Avatar
Some of the supply runs. I believe their is a total of around 130 over 4 floors, fed by 5 seperate systems. Will be fed from a remote location by chillers circulating chilled water.
Old 06-20-2009, 11:35 AM   #3
747
747's Avatar
Thats nice. Its a pretty expensive system. A high velocity system. Which is nice. Because the vents in the room are low profile. I've seen them use that on this old house. Not that often though because there not into forced air for heat. Usually hotwater. Are they using for heat also or just AC? You can also paint those little round holes where the air comes out to match the room So you really cant see them. They blend in nicely. When hanging those unit's you have to use the rubber things to minimize vibration. Pic 1 is what i'm talking about. Rich T on this old house was showing that during installation.
747 is offline   Reply With Quote
Old 06-20-2009, 11:41 AM   #4
loneframer's Avatar
Because of the lengths of run, alot of diffusers had to be added to make up for it. It appears to be a good system for the site conditions. (Metal framing and concrete floors.) Still alot of ductwork to be ran, pictures to follow.
Old 06-20-2009, 11:49 AM   #5
loneframer's Avatar
Heat is radiant in floor, all four levels. The diffusers are rectangular, see pic. They will be painted. All the units are hung from the rafters with isolation springs, the ductwork will be supported by ridgid foam cradles.
Old 06-20-2009, 01:14 PM   #6
J F
where did everybody go?
J F's Avatar
looking at all that duct work I can't help thinking about the "Aliens" movies
I might have to leave the wall coverings off if it was my place...looks pretty cool
J F is offline   Reply With Quote
Old 06-20-2009, 01:17 PM   #7
Professiona Instigator
rbsremodeling's Avatar
Trade: Design Build Remodeling Contractor Washington, DC
i think I am doing the exact same job. I can't take pictures though the owner is a D*** and won't allow it.
I have installed quite a few of those systems. If installed right they are very nice. and usually no bulkheads
rbsremodeling is offline   Reply With Quote
Old 06-20-2009, 01:57 PM   #8
Trade: HVAC
That is a beautiful system.
pyroracing85 is offline   Reply With Quote
Old 06-20-2009, 02:03 PM   #9
I just notice they have the duct work attached to regular metal register. They did not use the cool 4 inch plastic ceiling register?
Old 06-20-2009, 02:27 PM   #10
Trade: HVAC
Those aren't regular rectangular register boots.
those are high velocity slotted boots.
made for HV systems.
If youo connected a HV to a regular boot/register, it wouldn't work.
beenthere is offline   Reply With Quote
Old 06-20-2009, 04:25 PM   #11
loneframer's Avatar
Yes, it is a high velocity system. Actually all five units are.
Old 06-21-2009, 03:12 PM   #12
747
747's Avatar
Thats what i'm talking about. When those are mounted in a ceiling there so low profile if painted to match ceiling you really can't see them. Especially if you tuck them like in the corners of a room.
Old 06-24-2009, 09:44 AM   #13
A.D. Const's Avatar
Trade: A.D. Contracting & Remodeling LLC.
In my opinion you are getting the best of both worlds, congratulations. Looks like a very nice installation.
A.D. Const is offline   Reply With Quote
The Following User Says Thank You to A.D. Const For This Useful Post:
loneframer (06-24-2009)
Old 06-27-2009, 01:20 PM   #14
loneframer's Avatar
Just a few updated pics, space is getting tight.
Old 06-27-2009, 01:23 PM   #15
loneframer's Avatar
a few more
Old 06-30-2009, 06:21 PM   #16
loneframer's Avatar
Here's a couple of Money Mike, the man responsible for creating this monstrosity.
Ipe Clip Extreme vs. screw & plug. Mr. Fixer Decks & Fencing 5 05-17-2009 12:27 AM
Business Card Extreme wallmaxx Business 7 04-12-2009 11:13 AM
Extreme Home Makeover Has Come to Town ChrWright General Discussion 8 03-30-2009 08:32 AM
Extreme Website sitegrader Excavation & Site Work 25 03-11-2009 11:34 AM
FAT MAX Extreme DecksEtc Tools & Equipment 25 07-18-2006 05:53 PM
