Pittsburgh
Guest
Posts: n/a
Existing 80% Staying, Replacing Gravity W/ 90% Venting Question
I am buying a house that's been split into two apartments. One apartment has a new 80% furnace. The second apartment has an old gravity furnace that I am replacing with a 90% furnace. Both of the existing furnaces vent into the masonry chimney. I don't think that there is a condensation problem now since the gravity exhaust is so warm. However, when I install the 90% furnace, what is my best venting solution? Stainless Steel flue liner? Or can the 80% and 90% both go out a PVC vent?
Re: Existing 80% Staying, Replacing Gravity W/ 90% Venting Question
90+ is a seprate flue to the outside, do not connect to the flue.
Leave the 80% where it is just block off the old opening where the old unit connected. Benie |
#3 | |
Unregistered
Guest
Posts: n/a
Re: Existing 80% Staying, Replacing Gravity W/ 90% Venting QuestionQuote:
Is the flue on the inside of the home? if so no liner is needed.
However if the flue is on the outside of the home, you may need a liner as the flue will not be heated by the old unit. Bernie |
| Basement Window Question | gregt848 | Windows, Siding and Doors | 9 | 07-26-2006 06:29 PM |
| Roof venting question (help!) | happy_will | Roofing | 9 | 03-18-2006 03:41 PM |
| Venting 80% furnace & water heater | Unregistered | HVAC | 7 | 02-11-2004 06:13 AM |
