Exhaust Fan Roof Caps Leaking - Need New Solution
Old 06-16-2009, 01:06 PM   #1
f2contracting's Avatar
Trade: Home Renovation
I am having a problem with rain water coming in the roof caps for the bath exhaust fans. Heavy Texas thunderstorms blow in water, which runs down the pipe into the fan and ultimately into the ceiling damaging the drywall. Has anyone else had a problem like this? Do I need a different type of roof cap? I am attaching a photo of the one I'm using.
f2contracting is offline
Old 06-17-2009, 11:56 PM   #2
manager
greghvacguy's Avatar
Trade: heating cooling tech
Re: Exhaust Fan Roof Caps Leaking - Need New Solution
There is a damper/flapper on it. sounds like it is not closing. I have one on my dryer and lint gets n it and stays open I clean it every 90 days and no leaks.
greghvacguy is offline
Old 06-18-2009, 05:46 PM   #3
DuMass's Avatar
Trade: EC/ACR
I’ve installed a lot of those Nutone Scovill/Broan caps over the years.
One thing that comes to mind is roof pitch. If it’s a flat roof or has less than the manufacturers recommended minimum pitch, then water leakage like that can definitely happen.
DuMass is offline
Old 06-18-2009, 06:46 PM   #4
Is someone pushing the pipe
up so far that it holds the
damper open?
neolitic is offline
Old 06-21-2009, 02:10 PM   #5
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
with winds blowing the rain in i think a rubberized roof flashing with a 3 or 4 inch pvc leader and a gooseneck or tee termination would do. maybe coming up with a tee drip legg and drain system like in the old original black cpvc flue pipe system. goodluck
NickTech is offline
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
Frost on underside of roof sheathing ApexCS Remodeling 5 01-15-2009 01:55 PM
Deck stairs with a roof?? workswithwood Decks & Fencing 5 05-13-2008 11:23 AM
roof valley Fix-it Carpentry 3 11-12-2007 07:41 PM
A roof leak AbeBarker Roofing 8 02-18-2007 03:13 PM
