Trade: Mechanical Contractor
Evaporator Coil Leaks
We have been experiencing a higher than usual evaporator coil leakage rate in systems being installed in new homes here in Florida. The culprit seems to be formicary corrosion identified by the many pin hole leaks in the fin tubing of the coils. Nearly 80% of the York and Coleman systems installed in the past 2 years by my company has had the coil replaced and in some cases have been replaced multiple times. Has anyone else in the south experienced simular problems????Curious to how wide spread this really is???
Trade: Licsenced HVAC-R contractor located in the Chicagoland area providing service installation & design
Re: Evaporator Coil Leaks
I don't know if it is a regional issue. Have had the same problems you just described up north in Chicago, Just change out another one yesterday that had only seen one heat season.
CALL 773HOTCOLD.com for Chicago's #1 Heating Repair Service |
Handle It!
Sounds like time for a recall!!!!
Trade: Air conditioning
After 5 years of being told we were the only one having the problem, we gave the distributor and the manufactor so much trouble, they fired us. After 30 years of representing their brand, they fired us!
I guess they solved the problem. |
| searching for possible leaks | flashheatingand | HVAC | 5 | 09-07-2008 12:16 PM |
| Chimney leaks, permeates water | beavhut | General Discussion | 10 | 09-02-2008 05:40 PM |
| Torch down Roof Leaks with leaks | plazaman | Roofing | 5 | 02-16-2008 12:34 PM |
| Aluminum storefront door leaks | fabos | Windows, Siding and Doors | 0 | 05-12-2006 12:13 PM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
