photogoat
Guest
Posts: n/a
Emergency Heat Runs All The Time
the unit is a Goodman all electric heat pump. If the breaker is on, the fan and emergency heat is running.
Even with the thermostat turned off. Which was just replaced by the way, hoping to fix the problem. I disconnected the W and E inside the cabin of the emergency elements. no help. disconnected to the low voltage Defrost at the compressor. Kept running. It runs with the heat and cool also. Is this a stuck relay? A switched wire? Cant decipher diagram at relay near heating elements. Could it be a relay at the compressor? please help! |
MALCO.New.York
Guest
Posts: n/a
Re: Emergency Heat Runs All The Time
Hmmmmm....
Did it run PRIOR to the installation of the New T-Stat????? If not...The simplest route to the problem is the last change made. MISWIRED T-Stat was the first thing that came to mind to me before reading the rest of the post. The other is a bad Sensor/Switch or PC Board. |
photogoat
Guest
Posts: n/a
its ran this way since we got the house last year. i unhooked the aux for the summer but now i need it.
the t-stat isn't the problem.. how do i test the defrost board, or maybe its getting its power straight from the breaker. |
mickeyco
Guest
Posts: n/a
Call the HVAC guy and be sure to offer him some hot cocoa.
photogoat
Guest
Posts: n/a
i took the two low voltage wires off of the double switch relay at the heating elements, and the fan and elements stayed on. So I am assuming that the relay is welded shut and is bypassing all commands from the thermostat and defrost protocols. I guess I'll buy a new relay.?
#6 | |
MALCO.New.York
Guest
Posts: n/a
Re: Emergency Heat Runs All The TimeQuote:
Flick all the relays as if you were flicking someones ear. They are electro-mechanical and do have a moving part. Sometimes that is all it takes for the quick fix (not repair). Little Blue ones. Little Black ones and some 1x1x1's probably. They are often clustered (located in a group). Last edited by MALCO.New.York; 12-24-2008 at 11:37 AM. |
flashheatingand
Guest
Posts: n/a
Usually, if a relay sticks once, it is going to stick again. One might as well replace it. We call the relays, that energize the elements, sequencers. There is a thermal disc that heats up when energized (24volts) in the sequencer. That disc is what closes the contacts between line volts and the element. Some furnaces have the relays on the control board. Just from what I have read, I think Photogoat is on the money.
#8 | |
Dr Heat
Guest
Posts: n/a
Verbal
Guest
Posts: n/a
erase this
photogoat
Guest
Posts: n/a
it worked! i ordered a new double pole double throw relay, and it fixed it. the new one made a clickedy sound when i shook it, and flipped when i touch a 9V to it. the old one acted like a rock. thanks for the inspiration everyone.
flashheatingand
Guest
Posts: n/a
Good for you.
photogoat
Guest
Posts: n/a
True the old relay was stuck but the one a HVAC pro gave me was the wrong type. It doesn't connect the wires in the right config. I banged on the old one until it became unstuck and hooked it back up, but it just buzzes and doesn't stay in contact anymore.
This new one looks the same on the outside but the diagram is different, didn't think anything of it at the time. But when it got cold again, I noticed I had no Emergency heat. I used my Ohm meter to see how this new one worked and its way different. So now we are cold on New Years Day when everything is closed. You can bet I will take my Ohm meter to the supply house when I go to buy another one. Arggh |
westernhvac
Guest
Posts: n/a
Wouldn't that have been a lot easier if you just called a professional?
Dr Heat
Guest
Posts: n/a
Re: Emergency Heat Runs All The Time |
| Ceramic Additives | Nathan | Painting & Finish Work | 42 | 02-02-2010 04:13 PM |
| heat shrinks | pat c | Electrical | 7 | 09-17-2008 05:36 PM |
| Heat loss calculations | Paul B | HVAC | 6 | 09-15-2008 06:56 PM |
| Termite damage/hydronic floor heat | zkt | Flooring | 1 | 09-07-2008 06:23 PM |
| Water damage fan runs but no heat | IfMineItBr8k | HVAC | 4 | 03-02-2005 02:52 PM |
