Originally Posted by michigan roman
thanx for reply . yes these are rigid old oval / flatish type say 12 " in diameter pipes running as the main return trunk in attic , it runs back to the main return boot sticking through the ceiling from the furnace . i was hoping for an easy fix because the pipe lengths are all say 6' , the main line and each run from that line to individual rooms , and many of the unions between lengths have been sat on or kneeled on by people working in / using attic so ide have to dig out around each joint in all the dusty paper insulation and reshape the pipe then i guess tape it secure . then i guess have the return run vacumed out by one of those big trucks . alot of dusty work plus some cost as opposed to sealing off the runs .
though im wondering in this say 30 x 50 home would i have to keep all the runs intact or could i just seal up / fix a few of the ones nearest the trunk and eliminate the rest ? can you tell i dont want the job in that dusty old insulation
Well since I live in Mi too I have a "feel" for the types of construction in our state.
I would just replace the bad pieces. It's not that hard and oval pipe is still common these days. Easy DIY project.
Just stay away from Lowes and HD for duct fittings. They charge so much the cashiers should be wearing masks and holding a gun on you when you pay for it.
Decide to do it yourself PM me ....assuming i have PM ...I'm new here to, if not post back here an i can put you in touch with somebody who will sell fittings to you at reasonable price.
