Electric Radiant Heat Under Laminate Floor.
Old 10-21-2009, 10:23 PM   #1
Chris R.'s Avatar
Trade: Remodeling, Cabinetmaking
I am starting to remodel a bedroom that has electric baseboard heat. The baseboard heaters limit where furniture can be placed. I will be installing laminate flooring. The owner asked if there was any type heat that could be placed under the laminate flooring. the laminate will be laid over a wood subfloor. The floor has R19 fiberglass between the joists. What options are there & will it work well & hold up?
Chris R. is offline
Old 10-21-2009, 10:37 PM   #2
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Re: Electric Radiant Heat Under Laminate Floor.
There are several electric radiant systems that are made for use below a floating laminate floor. These are similar systems to those for use under tile.
Here is one manufacturer:
http://www.nuheat.com/products/electric-floor-heat.html
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 10-23-2009, 08:20 AM   #3
Hvacr Professional
Hvacpro's Avatar
Trade: Hvacr Pro
they use this type heat in the coldest regions.
its 100 percent efficient.
Hvacpro is offline
Old 10-23-2009, 11:39 PM   #4
Chris R.'s Avatar
Thanks for the replies & the link. I have been researching on the internet. There are a lot of different systems. Maybe the remodeling show will have some I can look at.
Chris R. is offline
Old 10-24-2009, 08:08 PM   #5
Warmsmeallup's Avatar
Trade: Sales/Distribution/Installation of low or line voltage radiant heating and snow melting systems
You can use Zmesh low voltage directly under the laminate. If you need to, it can also be nailed through anywhere without damaging the element.
http://www.comfortradiant.com/zmeshinterior.php
Warmsmeallup is offline
Radiant Heat Continuing Edu rickmccarthy Plumbing 0 07-20-2009 04:07 PM
Most efficient cost effective radiant floor setup Morning Wood Plumbing 4 05-18-2009 09:14 PM
Radiant floor heating in a large house KesslerDweller HVAC 2 02-21-2009 08:40 PM
Radiant Heat demaat HVAC 6 11-16-2008 07:52 PM
Basement Slab with Radiant Heat plazaman Framing 6 10-13-2008 05:35 PM
