Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 12-21-2006, 09:42 AM   #1
Trade: Rough / Finish Carpenter
Ducting dripping water
I have heard of this twice now and was wondering if anyone knew of a cause/solution...
I recently finished a basement and the drywaller asked me prior hanging if I was going to wrap the duct work to prevent dripping. Just this morning a co-worker said his unfinished basement floor had water (enough to make a small puddle and cover a 2x4 on conc) and the source was a joint in the ducting of the furnace. He pushed on the joint and a small amount of water came out of the seam.
I have seen water lines sweat, and drip, but never a duct of a furnace.
What causes this?
FYI - I am in the middle of Iowa so the A/C is not in use (if that makes a difference)
darcar is offline   Reply With Quote
Old 12-21-2006, 10:28 AM   #2
The outside of ductwork can "sweat" when running the A/C if exposed to warmer, humid air. It often happens in basement ductwork so it is a good idea to insulate the ductwork. But your freind has a different issue. I suspect his humidifier is cranked up to high.
gregj is offline   Reply With Quote
Old 12-21-2006, 03:02 PM   #3
MSSI's Avatar
Trade: Electrician
In the winter the warm moist air in the duct will condense inside the duct when it hits the cooler air of the basement or attic...
In the summer the water vapor in the warm moist attic or basement will condense on the outside when it hits the cold duct.
MSSI is offline   Reply With Quote
Old 12-23-2006, 09:31 AM   #4
snapperhead's Avatar
Trade: commercial hvac repair and installations
check the water level within the discharge duct mounted humidifier,from being algea coated to the fan taking the water drops right off the wheel
snapperhead is offline   Reply With Quote
#&*@! Water Hammer! Mike Finley Plumbing 19 02-22-2007 11:47 PM
Is it safe to drink water from Hot water Heater? robertc65 Plumbing 14 02-04-2007 12:11 PM
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 08:48 PM
