Duct Sizing
Old 04-29-2007, 07:41 AM   #1
sdbrown1's Avatar
Duct Sizing
Hello all and thanks in advance to you
I have a house 1st, 2nd,3rd floor. My question is, what size duct should i use for each floor?
does the 6 inch duct give more of an illusion of force on the room end as apposed to the 8 inch duct
sdbrown1 is offline
Old 04-29-2007, 09:00 AM   #2
Diesel65's Avatar
Trade: HVAC Contractor/ General Contractor
Re: Duct Sizing
Nowhere near enough info, how many units, what size, appx square foot of each floor, hard duct mains or all-flex system, would be a start.
A 6" flex carrying the same cfm's of air as an 8" will have a higher velocity but will also need an increase in static pressure to accomplish, there-by creating a problem with the design of the rest of the system.
A 6" flex will carry appx 225 cfm's at the Trane recommended max (for residential) of 1200 feet per minute.
An 8" will carry appx 420 cfm's to carry 420 cfm's in a 6" flex you would need appx 2400 feet per minute FPM which is twice as much as the average residential design will allow (getting on for nearly 2.0 static) which a standard a/c system cannot produce.
Diesel65 is offline
Old 04-29-2007, 08:28 PM   #3
sdbrown1's Avatar
Re: Duct Sizing
the house is 2200 sq feet. I intend to use sheet metal type ducting.
sdbrown1 is offline
Old 05-06-2007, 08:05 PM   #4
able14's Avatar
Trade: plumbing heating &ac
Re: Duct Sizing
recomended cfm for 6 inch is 100 cfm and around 220 for 8 inch you need to do a heat loss heat gain by room to see what size duct you need to run
able14 is offline
Old 05-13-2007, 07:14 PM   #5
national's Avatar
Trade: HVAC
Re: Duct Sizing
what does everyone usually use as a standard for a 12x13 room..id use 1 7 or 2 6's normally
national is offline
Old 05-13-2007, 07:48 PM   #6
Thom
thom's Avatar
Re: Duct Sizing
12X13 is borderline 1 @ 6". any larger would be 2@7'. Two windows in the room would bump it up to two as would a skylite. This is with refrigerated air. Evaporative cooling would require boosting duct size to 7".
I am in a moderate climate (Albuquerque). A harsh climate could change things as could a more moderate climate.
thom is online now
Bidding strapping and taping old duct work temporarily Brendakeen HVAC 3 05-10-2007 05:52 AM
duct taping your joints Travis HVAC 14 05-06-2007 08:34 PM
duct sizing sdbrown1 HVAC 4 08-08-2006 10:49 PM
primer/sealer or sizing steeleroller Wallpaper 3 03-09-2006 04:33 PM
Sizing duct questions goalmakers HVAC 1 02-24-2006 03:36 PM
