Duct Sizing
hello,
I have a 2200 sq ft house. with 1st 2nd and 3rd floor. what size duct should i use for each floor. |
Trade: hvac
Re: Duct Sizing
first and formost you need to determine size equipment that will heat and cool your house. load calculation must be performed to decide size of furnace and a/c. hvac talk forum has the load calc that you can do this on your own. In the past in new jersey the company i worked for would calculate by rule of thumb. 2200 sq x8 x5 = 88,000 btu heat /2= 44,000 btu cooling (3 1/2 tons) beware things are differant in other parts of the country.(To big a system= mold,noise wasted energy. to small hot and cold= angry,sick
3.5 tons= 1400 CFM being 3 floors.is it best to go with 2 systems.or multi zones.YES or you will never get even temps.with out knowing the lay out of the house, sq ft of each floor furnace location, |
#3 | |
Trade: Painter
Re: Duct SizingQuote:
How is it that you can develop mold from having an oversized system? |
Trade: hvac
Re: Duct Sizing
An over sized system will shut down to quickly or not run that long due to very cold air being place in the area,(feeling cold but clamy/damp.like a cool damp basement). A air conditioners job is to remove moisture from the area.A properly sized a/c will run long enough to remove the water that is in the air.
A good effianct a/c will run longer then a oversized one will. and still be very comfortable in the area. load calc is the only true way. |
| Duct sizing | sdbrown1 | HVAC | 5 | 05-13-2007 07:48 PM |
| Bidding strapping and taping old duct work temporarily | Brendakeen | HVAC | 3 | 05-10-2007 05:52 AM |
| duct taping your joints | Travis | HVAC | 14 | 05-06-2007 08:34 PM |
| primer/sealer or sizing | steeleroller | Wallpaper | 3 | 03-09-2006 04:33 PM |
| Sizing duct questions | goalmakers | HVAC | 1 | 02-24-2006 03:36 PM |
