Duct Sealing
Old 06-08-2009, 10:54 PM   #1
mgimbrere's Avatar
Trade: Design and Build Contractors
Duct Sealing
I have an HVAC contractor who is a great technician and an apparently good system designer. He tells me that duct sealing is overrated and that sealing with metal tape is just as good as sealing with mastic. I continue to doubt him about this, but I am open to other professional's opinions.
What do you folks think? Thanks.
mgimbrere is offline
Old 06-09-2009, 01:23 AM   #2
BrianfromPomona's Avatar
Trade: HVAC
Re: Duct Sealing
I work in Commercial only, and 99% of the time we only use duct sealer, usually DP1010 or DP1020. I only use tape when i'm in a position that is tight, or where I will get wet with the duct sealer. In certain situations we will use regular duct tape, then seal over it with DP1010, which also works well.
I believe metal tape is good in certain situations such as connections at the furnace and on plenums, but if its on spiral or rectangular duct, tape wouldn't work and it would take longer. Metal Tape is code, so its as good when used correctly.
BrianfromPomona is offline
The Following User Says Thank You to BrianfromPomona For This Useful Post:
mgimbrere (06-10-2009)
Old 06-18-2009, 05:59 PM   #3
DuMass's Avatar
Trade: EC/ACR
Re: Duct Sealing
I agree that the ducts should definitely be sealed at the time installation.
They are not going to get any tighter by themselves as time goes by!
DuMass is offline
Old 07-07-2009, 09:10 AM   #4
jw05450's Avatar
Trade: hvac
Re: Duct Sealing
Duct sealer all the way. Its a cheap insurance policy to make sure you have a tight system.
jw05450 is offline
Old 07-07-2009, 10:19 AM   #5
beenthere's Avatar
Trade: HVAC
Re: Duct Sealing
If its mastic tape, ok.
If its just silver tape, nope.
beenthere is offline
Old 07-07-2009, 04:14 PM   #6
rjconstructs's Avatar
Trade: Residential remodel
Re: Duct Sealing
I've only heard good things about duct sealer.
rjconstructs is offline
Insulating duct work john916 HVAC 4 02-19-2009 07:38 PM
duct design and adding on questions 72chevy4x4 HVAC 4 01-20-2009 10:45 PM
duct or flex ? odellconstruct HVAC 3 01-13-2009 07:34 PM
Metal ducts or Flexible duct in use? Charlot HVAC 2 10-30-2008 04:52 AM
un wrapped duct work ofourcobra HVAC 10 09-26-2008 08:29 PM
