Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 12-25-2008, 10:08 AM   #1
Trade: home builder
drywall dust and furnace don't mix
I have a Goodman gmh 92k 2stage gas furnace with 5 ton A coil that is plugged up with drywall dust. I blew out the A coils the best I could with an air hose. What other problems/areas do I need to look into if any????????
banctecbobn is offline   Reply With Quote
Old 12-25-2008, 02:20 PM   #2
A.D. Const's Avatar
Trade: A.D. Contracting & Remodeling LLC.
What happenned? Some one forgot to put up a filter? for how long was it like that? Motor might be going if coil was clog and no air flow. Kind of hard to tell you with out some more info.
A.D. Const is offline   Reply With Quote
Old 12-25-2008, 03:44 PM   #3
Houston's's Avatar
Trade: remodeling, replacement windows,
Like a jack ass i did the same thing and my motor went out soon after.
I say check the motor housing and blow out the dust in it also.
Houston's is offline   Reply With Quote
Old 12-26-2008, 02:38 PM   #4
A.D. Const's Avatar
Yes it happens, the sad thing is that with these H. Eff units sometimes just blowing the coil in not enough, It seems to work fine for a bit and then boom motor goes. He'll be better off having someone use an approved cleaning detergent or foaming agent, it does a much better job, but in an evaporator it quite a hassle, depending on its location.
Old 01-13-2009, 08:09 PM   #5
Dr Heat
Dr Heat's Avatar
Trade: hvac
if it is a high efficient furnace clean the secondary. If you don't know what that is Hire a pro. Drywall dust alone cleans up easily, blow it out dry then vac. foaming coil cleaners are usually called no rinse this only applies in ac mode.
Dr Heat is offline   Reply With Quote
Geothermal to heat house under construction? GregWCIL HVAC 9 11-26-2008 01:30 AM
Carrier 58GFA furnace problems rakes9720 HVAC 23 01-12-2008 11:45 AM
furnace won't work Scott dev HVAC 6 12-09-2007 01:27 PM
Blower motor in old GE furnace.. pwhited HVAC 2 02-16-2004 06:56 AM
