Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 08-24-2009, 09:08 AM   #1
Trade: H.v.a.c.
dryer venting: up versus out
Granted, when the dryer is locatd on an outside wall, just shoot it outside straight from the back...Simple Simon. However, upon several instances, I run into situations in which the dryer is on an interrior wall, and the distance is about 18' from the outside.
Sure, you can still go horizontally in the crawl space, but if it is a single story house, going straight up, may be a better option. No matter what, is that lint is going to build-up. It is easier to clean the inside of the pipe, using a brush going up and down versus the horizontal run.
Only thing is a back-draft damper.The set-up needs to be so that youcan easily take off the deflecto .
flashheatingand is offline   Reply With Quote
Gas Dryer Venting Winchester HVAC 12 02-25-2009 08:10 AM
dryer venting hughjazz HVAC 3 02-12-2009 10:53 AM
dryer vent code Kevin75 HVAC 3 09-03-2008 08:34 PM
Dryer/HVAC venting Kevin75 HVAC 17 08-28-2008 07:09 PM
Venting a dryer through a soffit ChuckEA HVAC 12 05-24-2006 05:20 PM
