Dryer Venting
Old 02-12-2009, 01:00 AM   #1
hughjazz's Avatar
Trade: carpenter
Dryer Venting
Hi guys, this is in my own home, but I was hoping someone wouldn't mind giving me a quick answer.
I just moved into my new house recently, up until now I have been venting my dryer with a stocking.
I have a vent fitting cut into my rim board. My question is this,
I plan to run flexible ducting (4") about 8' up and about 4-5 ' horizontal.
The ducting will probably end up being 12' or so?
Is this okay? Probably an easy question but I'm a framer so I'm clueless about this.
Thanks
hughjazz is offline
Old 02-12-2009, 08:35 AM   #2
Tom M's Avatar
Re: Dryer Venting
The piping needs to be smooth and shouldnt have any screws. These things collect lint and cause fire. If the manufacturer gives a maximum distance of pipe then use it if it sends you to the building code then use that. We run on IRC, 25 ft is the maxium distance allowed. For every 90 degree elbow the length gets reduce by 5ft, every 45 degree elbow reduces 2 1/2 ft. So a 25 ft run with 2 90's limits you to 15 ft. The first elbow coming out of the dryer itself does not need to be included.
Tom M is offline
Old 02-12-2009, 09:16 AM   #3
flashheatingand's Avatar
Trade: H.v.a.c.
Re: Dryer Venting
As Tom indicated, you need to run the line in hard pipe. A short piece of flex pipe off the dryer is ok, but the run should not be done with flex.
flashheatingand is offline
Old 02-12-2009, 10:53 AM   #4
hughjazz's Avatar
Trade: carpenter
Re: Dryer Venting
ok thanks, i was planning to buy 15' of that slinky type plastic dryer hose, but thats no good right?
I will buy some metal piping, thanks guys,
hughjazz is offline
Venting furnace and water tank nzavorek HVAC 22 02-06-2009 08:54 AM
dryer vent code Kevin75 HVAC 3 09-03-2008 09:34 PM
Dryer/HVAC venting Kevin75 HVAC 17 08-28-2008 08:09 PM
gas dryer next to 3 gas water heaters fast pasquale Plumbing 9 05-26-2007 11:28 AM
Venting a dryer through a soffit ChuckEA HVAC 12 05-24-2006 06:20 PM
