Draft Regulator
Old 01-04-2009, 04:09 PM   #1
mrmike's Avatar
Trade: Electrical & Carpentry
Draft Regulator
Is it normal to not have a draft regulator on the pipe from a hot air furnace to the flue on the chimney? Doing some wiring for a customer & his furnace had quit & he reset it 3 or few times without it firing, so of course pumped oil into the firebox, He called me up & I changed nozzles & cleaned it etc, & as soon as I fired it I could tell something was wrong- " the excess oil burning, so I shut it down immediatly. Let the thing burn off with it blowing smoke out of the flue pipe joints. Thats when I saw no draft regulator on it........... Mike
mrmike is offline
Old 01-04-2009, 07:24 PM   #2
Plumbing is a Profession
nhmaster3015's Avatar
Trade: Plumbing & HVAC
Re: Draft Regulator
Unless the manufacturer says otherwise it should have a draft regulator installed.
nhmaster3015 is offline
Old 01-13-2009, 07:53 PM   #3
Dr Heat
Dr Heat's Avatar
Trade: hvac
Re: Draft Regulator
it is a draft divert er and if it a newer oil furnace it may be built into the back of the furnace.
What is the age,make and model.
I once was called out to service an oil furnace, when i arrived I asked if the ho had hit the reset. Oh yes three times just like the label said, said the ho. So I got a dime a nickle some emery paper tuned her up just wright primed the single stage pump and let her spark. The whole fire box became engorged in flame puffing black smoke into the house the flue pipe turned a curios shade of red and ho called the fire brigade. Before they arrived the fire burned out and all was well. Lesson learned don't trust HO check the box for a puddle of oil.
Dr Heat is offline
Old 01-18-2009, 10:40 AM   #4
MechAcc's Avatar
Trade: HVAC Service Technician --RSES CM-- NATE Certifie
Re: Draft Regulator
Don't you love the new Honeywell Primary Controls that you have to push and hold the button for at least a minute. Sure cuts down on HO over resetting the control.
MechAcc is offline
Double flue down draft ELM Masonry 17 10-28-2008 07:48 PM
Down Draft Vent DEKAN Kitchens & Baths 2 09-06-2008 04:11 PM
draft cover swamp cooler kevjob HVAC 0 06-24-2008 11:30 PM
What is this? Pressure Regulator? jicoll2000 Plumbing 11 12-18-2007 11:09 PM
Squeaky regulator Leo G HVAC 0 04-05-2006 01:36 PM
