Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 03-19-2007, 05:56 PM   #1
Ready 4 Rent
Trade: Property Maintenence
Double Brick, Or Roof? Dryer Vent
Hope some-one can help me out here, got a customer that wants to install a dryer/washer in and upstair apartment. I don't do that type of thing but would like to point him in the right direction. His major concern is how to vent the dryer. It's a older home, double brick. Seeing as it's upstairs is a roof vent the way to go, or go through the double brick. Which way is recommeded? And what would you use to go through the brick?
Any suggestions would be good, Like I said I told him I won't do it, but would like to point him the right way.
Cheers
John
www.ready4rent.ca
John S is offline   Reply With Quote
Old 03-19-2007, 05:58 PM   #2
mdshunk's Avatar
I wouldn't hesitate for a split second to go through the brick. It's no big deal. Five minutes with a core drill, and you're done. Roof penetrations are the method of last resort.
mdshunk is offline   Reply With Quote
Old 03-19-2007, 09:33 PM   #3
Ready 4 Rent
Thanks mdshunk,! That's what I was thinking, just not possitive to pass it on, do you drill a guide hole first or just go at 'er?
John
www.ready4rent.ca
Old 03-23-2007, 05:58 PM   #4
Trade: hvac tech
pilot hole from inside first then go nuts
hf05 is offline   Reply With Quote
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Dryer vent question hanover Plumbing 12 11-15-2006 09:01 PM
Indoor dryer vent bucket Chris G HVAC 3 08-02-2006 05:28 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
