Czars
Trade: Electrical Contracting
Disable Goodman Heat Pump Compressor
I want to disable a Goodman Heat Pump compressor when the outside temperature goes below 35 degrees F (heat strips are on) by interrupting the thermostat signal commanding to the outside unit to run. Can I just interrupt the 24 VAC to the outside unit?
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Trade: H.v.a.c.
Rewards Points: 3,470
Re: Disable Goodman Heat Pump Compressor
You can, with an outdoor t-stat wired in series to the low voltage circuit. Otherwise, you can manually switch it at your indoor t-stat, by manually switching to emergency heat.
http://www.37flash.com/ |
Czars
Is it acceptable to use the external T-Stat to interrupt the 24VAC going to the outside unit?
Carbon Dioxide Producer
Trade: EC
That is something that can be done easily with a better quality thermostat, like the HW VisionPro along with their optional OD temp sensor. You can program it for compressor lockout below a certain OD temp and run only the aux heat strips. You can also program it to lockout the aux heat strips when the outdoor temp rises above a certain point.
When the OD temp is in between these two set points, the system operates normally with compressor and aux heat strips as needed. |
#5 | |
Trade: HVAC
Rewards Points: 1,112
Re: Disable Goodman Heat Pump CompressorQuote:
Don't know why you would want to shut off the heat pump at 35 though, its still cheaper then just using the strip heaters at that temp. |
Trade: hvac
Re: Disable Goodman Heat Pump Compressor |
#7 | |
Rewards Points: 75
If you are using an older mechanical stat or even a digital stat that is not properly set up..........you can remedy the "cold" heat syndrome many comlain about at lower ambient temperatures by installing a GOOD digital stat that can sense outdoor temperature and when set up properly they will along for longer system run at colder outdoor temps plus you can set the point at which your electric heaters come on. Many times with the mechanical stat, cheaper digital stats, or improperly set up stat you can experience what is calling floating...where your heat pump simply runs and runs (typically would occur around balance point) without ever getting to the "trigger" point to bring heat strips on and without being able to satisfy the setpoint. So it runs, runs, and runs some more. There is a good article at http://hvacmarket.com/cgi/wp regarding thermostats....sorry I do not have the direct article link...it is in there somewhere. Using the correct Honeywell visionpro stat, you can use an outdoor sensor at the unit and setting the stat up for the application you can do just that. AdvertisementLast edited by user84377; 01-07-2012 at 10:52 AM. |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Heat Pump | Mike- | HVAC | 16 | 10-24-2011 11:21 AM |
Goodman Heat Pump | C comfort | HVAC | 9 | 01-08-2011 05:36 PM |
Heat pump SEER | readydave8 | HVAC | 4 | 06-13-2010 05:14 AM |
Friedrich 2 ton Heat pump fan speed | alansanders | HVAC | 0 | 11-18-2009 08:38 PM |
Heat Pump vs Central A/C | mugiber | HVAC | 8 | 11-03-2008 10:13 PM |
Go to Page... |
